NC24 600RR shock mod help needed
Re: NC24 600RR shock mod help needed
every problem has a solution
get a shorter spring?
- Bike owned: KS125, ER5,VFR400 NC24
Its looking like that will be the option out of this, I know it will reduce the travel on the shock.
Curently i have the bottom all mounted correctly but the top is like 35mm- 40mm out and i cannot compress the spring no more.
I can get more photos of this if needed to show all.
Also if i do get a new spring, anyone know how to change them over?
Okay, not to sound stupid. But could someone show me where i can get a new shorter spring from please.
demontweeks at a guess
I gave them an email, they asked me to let them know the "length" and "spring rate" needed
Also i cannot still work out why the damn thing wont fit if this mods been done a lot
EDIT: do you reckon the NC24's spring would fit on the 600 shock?
I've only ever seen it done once on this forum.chownsy wrote:Also i cannot still work out why the damn thing wont fit if this mods been done a lot![]()
Might be more out there, but it certainly isn't a common mod!
Are you sure it was from the same year model 600rr as in the original post?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:ITder~kire wrote:accqire 1 2004 showa cbr600rr gas shock,
Item did when i purchased it say "04" in the title
Both this and the one in the mod guide has 6 coils on the spring.
the bottom looks identical as to size and this photo
If you see the angled link arm, that looks identical to how mine looked when i had the shock fitted with the exhaust off.
I have just noticed that my bottom screw is set all the way to Hard (gussing this is for the damper)
- Bike owned: CB-1, MSX125
So you're doing this mod based on pictures from one chap, who you don't know for a fact ever finished it? Or that he ran it with a standard exhaust? Brave man!chownsy wrote:http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWNX:ITder~kire wrote:accqire 1 2004 showa cbr600rr gas shock,
The screw will be damping. I forget whether the bottom one is rebound or compression, but the other one of those will be on the top end of the shock somewhere.
Im doing it because:
A. I have little money to buy a Hagon shock at £300+
B. I have contacted a few refurbishers and they all said didnt want to touch my Shock to refurb it
C. The shock was cheap at £22 posted
D. I have the time on my hands to do any modifications needed, just need the occasional push in the right direction.
E. this mod and another member said its been done a few times.
If i can get it to work i can post all the modifications i had to do so future people can do it
If it all goes to pot and it fails. All i will have done is made the battery easier to access, the NC21 TDI unit easier to mount (i got a NC21 engine in the NC24 frame as it was a cheap engine i got hold of)
Hi all,
As i need a shock between 270 - 290ish mm long i have been googling these lenghts
Im guessing that this http://www.wemoto.com/parts/picture/HL-869125/ will not work on my bike as its off a 125, also not adjustable either.
From googling i have found that a RVF750 shock is 290mm long.
Im very very very near the point of putting a Hagon shock onto my parents credit card and adding it to what i owe them for other things i have bought.
