Page 3 of 4
Re: Guess what I'm doing??? (Ram-air on my VFR)
Posted: Sun Feb 05, 2012 9:32 pm
by viper_biker
The bike ran perfectly on its first track outting. I didn't have the chance to have it dyno'd as at the same track-day I ended up spending 5 day's in hospital after an off-track excursion with the bike stuck in the back of my knee. I'm currently building myself up a track-bike to a similar spec so will know in a few months time when it's all together and running.
Posted: Tue Feb 14, 2012 8:29 pm
by steve92
I think i've got it right, so where the cable ties are i just get a t piece and route them where the ties are?
So what are the air holes that need blocked up?
Also what do i do with the vacuum pipe now when i use the fuel pump, just block the hole up?
Next question lol, the pump has three tubes, does the 3rd small pipe go on to replace the vacuum hose?
Got the air box off GF
I was going to fit a light wire mesh on top of the bottom tray.
Also got the 135 jets all round and air screws out three turns.
I should get a little run out on saturday if all goes well.
Is there anything ive missed here? :rocks:
Posted: Tue Feb 14, 2012 9:39 pm
by royster81
Steve, are you racing the vfr in the preinjection class ?
Posted: Tue Feb 14, 2012 10:00 pm
by steve92
I'm not sure yet, not sure what class i can or should enter. I've to do another training day on the 4th of March then theres an open day on the 17th of March so i was thinking i can find out more info what to do then.
What options do i have?
Congrats on the new born.
Posted: Wed Feb 15, 2012 7:55 am
by royster81
Thank Steve.
The only reason I ask is I saw the rules on the preinjection and I don't think you can mod the carbs to run ram air, you can run the bike but if you get a jobs worth of a scrutineer or racer they have grounds for appeal.
Posted: Wed Feb 15, 2012 9:21 am
by mo haggs
You can run it in ss400, maybe see you out there.
Posted: Wed Feb 15, 2012 6:24 pm
by steve92
Yea i think ss400 is the way to go, i'd rather be out with other 400's
Yea should see you about Mo, lets hope for a good summer.
Can anyone answer some of the questions above?
Posted: Thu Feb 16, 2012 10:47 am
by viper_biker
Yes, join them with a t-piece and vent it into the air-box
There are 2 brass tubes on each carb, you need to block up the smaller of the 2
Block it up, either a grub screw that's the correst size, or a screw in the current vacuum tube
No idea what the 3rd hose is about, the 2 main tubes are fuel in and fuel out, is it an overflow of sorts?
What weight is in the GF lid? Ours is almost finished and ready to go into production next week, but it'll have a smooth gel-coat outter finish rather than the matt finish. Here's where ours is at at the minute, we made a frame to construct and the lid is made from a few different sections, but will be a well made and strong unit,
Posted: Thu Feb 16, 2012 10:54 am
by Drunkn Munky
As for jetting im sure mine use to 148's maybe higher
Posted: Thu Feb 16, 2012 11:24 am
by viper_biker
Drunkn Munky wrote:As for jetting im sure mine use to 148's maybe higher
Tony, I've not forgot about you either, we're gonna have these hopefully starting to be made from early next week so I'll be sending both your original and a new one shortly.
