Page 3 of 6
Re: How to Video: Replace Clutch Plates (NC30)
Posted: Thu May 06, 2010 7:29 pm
by micpec
Good vid! That looks so simple. So far I did not need to perform this clutch replacement, but it is handy to watch it and thanks for this leason.
Posted: Fri May 21, 2010 6:55 pm
I did 2 clutches recently and it is a simple job at the end of the day.
Good vid though, nice to have a look see if you have never seen the wonders of clutches!!
Posted: Sat May 22, 2010 8:09 pm
by Sligeach
you said it. it does seem a little daunting just looking at the tiny pics in black and white from the haynes, so a bit of colour and commentary from a paddy goes a long way
Posted: Wed Jun 23, 2010 12:31 am
by terryvxr8
Brilliant guide. Does anyone know if this is the same as the nc24, Thanks again..
Posted: Tue Aug 10, 2010 2:32 pm
NC24 is easier as it has not slipper clutch.
Remove clutch cover.
Remove 4 x shouldered bolts and springs.
Front comes off along with the plates and the steels.
The last plate is a spring washer, make sure it's in the right way.
EBC (from wemoto) do a heavy duty clutch spring set thats well worth a buy, i've had a couple of motors with weak springs.
Posted: Thu Aug 19, 2010 10:06 am
by superlite
Neosophist wrote:EBC (from wemoto) do a heavy duty clutch spring set thats well worth a buy, i've had a couple of motors with weak springs.
Out of curiosity, can you add an extra spring to NC21/24 as per NC30 to stiffen it up a bit? I'm guessing not if they only use one spring?
Posted: Wed Aug 25, 2010 10:14 am
by Sligeach
the 24 has coil springs unlike the 30 with diaphragm springs, so to stiffen things up you'd have to replace all springs
Posted: Sat Oct 30, 2010 11:51 pm
by Lope
is it possible to use NC30 slipper components in a NC24?
I have to be quite accurate rev-matching while gearing down before corners. Are slippers for lazy people? :)
Posted: Tue Nov 02, 2010 6:47 pm
The outer basket is the same on both bikes so I don't see why you couldn't transplant the middle out of the 30.
Although the NC30 clutch isn't like modern bike slipper clutches, unless you have componenets knocking around to do it I wouldn't bother.
Slipper clutch isn't substituion for good riding technique.
If it's becomming an issue maybe your riding too fast for the road?
Posted: Tue Nov 02, 2010 6:48 pm
superlite wrote:Neosophist wrote:EBC (from wemoto) do a heavy duty clutch spring set thats well worth a buy, i've had a couple of motors with weak springs.
They use 4 coil springs.. EBC do a heavy duty set for pennies that are stiff as a corpse. Great springs if you have a strong hand.. if not you'll get one using them.. clutch is strong enough to pull a caravan
