Reg/Rec advice
Re: Reg/Rec advice
i just picked up one of these:
http://cgi.ebay.co.uk/REGULATOR-RECTIFI" onclick="window.open(this.href);return false; ... 3a53fbf968
works a treat and has sorted out SO many issues.
- Bike owned: '88 NC24
- Location: approaching the apex, carrying too much speed...
Re: Reg/Rec advice
Neosophist wrote:If you go for the R6 reg/rec it has 5 pins
[-]____[-]
[-]_[-]_[-]
if you look at it like that, top left is Red (+) top right is green (-)
The bottom 3 are the yellows (any order)
Just about to fit the new R6 reg, I'm guessing you put the two reds and two greens off the viffer loom together?
And the yellows any order?
Formerly RacingSlug. Felt like a change and it came down to either Biscuits, Ben10 (possible copyright issues) or NinjaSmokeWarrior. The wife suggested TwatMan.
Re: Reg/Rec advice
fitted. Sorted. Swear it actually runs better :)RacingSlug wrote:Neosophist wrote:If you go for the R6 reg/rec it has 5 pins
[-]____[-]
[-]_[-]_[-]
Re: Reg/Rec advice
Took mine off today, looks like it's cooked, the back has come apart by what looks like road shit from the rear wheel. Pin on the connector had scorch marks on it, and the whole unit seems to be weaping something black and sticky lol. Was supprised to see no heatsink on it though, and it's a pattern unit fo sho
Re: Reg/Rec advice
Ok. So I'm stood here halfway to work waiting for the mrs to bring my spare battery. Seems I have exactly the same problem. Still. My new 8ah battery got me about ten miles, taking it easy, Lights on. See if my old 14ah can get me home eh? What's the betting the genny has decided to cash it's chips?
Re: Reg/Rec advice
Lol... if you have lights on and your battery isn't charging your just gonna drain it :) While a 14ah one is no better it'll last a bit longer.RacingSlug wrote:Ok. So I'm stood here halfway to work waiting for the mrs to bring my spare battery. Seems I have exactly the same problem. Still. My new 8ah battery got me about ten miles, taking it easy, Lights on. See if my old 14ah can get me home eh? What's the betting the genny has decided to cash it's chips?
Do you not have a multimeter?
Usually a knackered / old battery or an old reg/rec or a combination of the two starts to kill one another.. if left un-checked will kill the generator too
http://www.electrexworld.co.uk/pdfs/Tro ... G-&-RR.pdf" onclick="window.open(this.href);return false;
follow that through, from the top! don't skip ANY steps and make sure you have a fully charged battery before you start!
Re: Reg/Rec advice
Will do Mr N, cheers for that, I'll do it in the a.m.
I'm leaving the bike till it's sorted, don't want to knacker the 'new' reg or me batteries.
(un?)luckily I've borrowed my moms metallic green 2 door 1.1 Fiat Punto. Rock & Roll.
Re: Reg/Rec advice
No problemo. Let me know how your gettin on with it.
Re: Reg/Rec advice
Right, finally got the time to look at the bike.
Going through the diagnostic steps Neo has linked to above;
Step 3 showed the battery was getting no charge, checked all the connections and tested again, bugger all was going into the battery.
Step 4 was ok.
Step 5 was measured in the 20k ohm range, all were 0.03
Step 6 results were 7.4v, 5.4v, 7.6v.
I stopped there.
Anyone got a NC24 genny for sale?
Step 4 was ok.
I stopped there.
Re: Reg/Rec advice
With the Multimeter set to AC, hold the RPM at 5000 and check between each phase (pair of yellow wires) you should have 50vRacingSlug wrote:Right, finally got the time to look at the bike.
Step 4 was ok.
I stopped there.
