xivlias "other" thread of multiple problems?
- missis sumner
- Bike owned: NC30 + Teapot
Re: xivlias thread of multiple problems?
the float needle valve/seat?
- missis sumner
And WTF?xivlia wrote:when the bike was off the road, i took the battery and used it on other things. lets not go into details with that.
- xivlia
- Bike owned: Ducati 749 D
ive checked the float valve seat and needle. they are all in perfect condition, and yeah, i needed a battery nickel plate a copper heatsink. so i used my nc30 battery for that, did the job.
the floats have a function that they open a needle to allow fuel into the chamber.
The needles and the seat that they sit in can become either corroded (probable with the water in the system) or something can get stuck and stop it sealing.
It works like the cistern on your bog - fills with fuel and the float then applies pressure to stop the fuel. Just like when your bog refills after flushing.
They can be fixed by replacing the float needle or by proper check to see it functions OK.
If you starting it running it for 5 or 10 mins and not riding it your battery will go flat if you do it over and over.
Turn off your tap overnight and see if your problem goes away?
- vfrman
- Bike owned: NC30, 1098s
If you are positive which carb was/is leaking, replace the needle and seat with a new one.
it will be the one that is filled with water/fuel Steve!
- vfrman
Duh! LOL. I would change the float needle and seat...but that is just me.
Contact Geoff, I'm sure he has carbs sitting at a reasonable price.
And they're guaranteed to be free of fox piss....
- xivlia
okay, i cannot believe this... today, the bike wont start.... it started for 3 seconds, and cut off. and never started since... checked for spark in the rear plugs... NO SPARK.... removed the plugs, checked for spark with just the HT coil.. NO SPARK.... i havent checked the front yet from all the fairings. but when i remove them i will check... but i can pretty much guess that its going to have no spark.... i am seriously getting tired.... why is this happening? i was riding the bike perfectly fine yesterday... what the fuck is going on. im sick and tired every time i fix something, another thing brakes. fucking hell!
