Page 17 of 19
				Re: Micpec's NC35's (and past bike)...
				Posted: Tue Dec 29, 2015 11:37 pm
				by micpec
				Thanks, Blair!
Brand is BGS Technic Germany werkzeuge; left one is for careful fitting of steering head bearings for specific honda/kawa and HD, middle one is a inner puller set with slide hammer for extracting bearings, sleeves out of blind holes (e.g. wheel bearings, engine bearings) and the last one is for motorcycle brake piston removal of all brands.
				Posted: Sun Jan 03, 2016 12:15 am
				by micpec
				awaiting a tool to fit the oil pressure sensor and also the custom rear brake disc. Next week Saturday more updates.
				Posted: Thu Jan 14, 2016 9:00 pm
				by micpec
				Had little time, but here is a small update.
Last weekend  I went back to Michael for more programming of the dash. He did some more research upfront and after some testing the oil pressure works and is now set perfectly. Must admit that this sensor is ones from his bike. The AEM psi sensor I got earier will be modified and will be used in his other rvf bike.
On the contrary the AIM water thermo sensor is playing up big time with some incorrect high/low readings. After multiple readings, testing and custom re-wiring this one does needs a bit more fine tuning on a later moment.
We fitted the carbs and also the gerd rads and connected new samco hoses with new hose clamps and filled up with water. I was a bit worried with my bike since the new gsxr genny conversion was just fitted few weeks ago and I had not tested this setup yet. In the end all operated good, the re-wiring and charging system didn't suffer from an issue. The throttle response improved a bit at first glance and for now only tested on the bench.
By twilight we closed the operation to wrap up the day, and moved my bike back in the trailer for my way home.
New updates will follow later. Now on the hunt for some other bits and pieces to show up and to get ready for next visit and continue assembly (e.g. custom rear brake disc, -wiring and -brake line routing in swing arm, speed sensor, gear shifting).
Michael mentioned...
Maybe it's 'another' never ending story.. Oops that an
No, I am awake, must resist. must resist.
Of course I wish
  it's like the carbon bike, because that is a true beauty!
Here back-to-back testing:
Here night view
(note the false reading of the water temp):
				Posted: Tue Feb 02, 2016 11:02 pm
				by micpec
				Posted: Wed Feb 03, 2016 12:17 am
				by Maelstrom
				Looking good!
I could use those measurements for my fork database.
http://litetek.co/Guide_USD_ForkDatabase.html
Are those lengths with the fork cap? If not could you give them without please.
cheers
Blair
				Posted: Wed Feb 03, 2016 8:16 pm
				by micpec
				Hi Blair,
No problem, I see what you are trying to collect in your data sheet
 The length of a 2011 fork d675 is 725mm measured from centre spindle bolt to top of fork, and should be similar to STR. Diameter triple clamp top fork clamp 50mm and triple lower clamp fork 52mm is similar to nc35, so straigh fit. NC35 standard fork length is 710mm. Discs is 5-bolts fitment 308mm ('13-on is 310mm), radial mounted calipers are 108mm, and d675 travel is 120mm, I believe STR have same 120mm travel (both dependant on the exact manufacturer year e.g. STR '09-'12 is 120mm, however '13-'15 is 115mm, and d675r have nix30 ohlins forks with 43mm stanchion and 110mm travel).
Jason
				Posted: Thu Feb 04, 2016 1:25 am
				by Maelstrom
				Thanks Jason,
Can I be a pain and ask you how thick the fork caps are. All of the measurements I have are sans cap.
A d675 is a Triumph, yes? (EDIT: Ok it is a Triumph Daytona)
What is STR?
EDIT:
I added that triumph information and some I found on Wiki to the page.
				Posted: Thu Feb 04, 2016 5:38 am
				by fourfingers
				Speed Triple?
You should be careful with newer fork mesurements, don“t know about triumphs, but cbr600rr 05-06, 07<, use a top out spring that make the forks look shorter tan what they really are.
I have a couple of cad drawings with measurements of forks, triple tree offsets etc, I will send them over, Blair. By the way, very nice carb gasket sets, got one nc35 installed, and an nc30 pending.
Cheers,
Emilio
				Posted: Thu Feb 04, 2016 5:50 am
				by Maelstrom
				Thanks Emilio.
All contributions gratefully accepted. I started that page because I was trying to find a front end for my FZR400. Hopefully it will continue to grow and be useful for the community.
				Posted: Thu Feb 04, 2016 7:59 pm
				by micpec
				Blair, STR is Street Triple R
Edit: more measurements of the forks for your sheet:
d675 1.7mm cap excluded nut, and top fork nut itself 5.5mm
nc35 3mm cap excluded nut, and top fork nut 7mm
