xivlia's thread of nc30 problems and questions
Where posts and threads can be moved to future safe keeping.
Locked
Deviant400
Bike owned: NC30, Kona Cowan
Re: Diffrent types of Gaskets?
Post by Deviant400 »
yeah well my rear manifold is connected to the heads using the correct ones as i had 2 spare , (slightly thicker with cloth type stuff between copper rings) but the front pipes are connected using the same as in your pic as is the rear pipes to the manafold , all seems ok
Deviants AM/PM build
viewtopic.php?f=62&t=27307
xivlia
Bike owned: Ducati 749 D
Post by xivlia »
hmm okay. itl probably be fine...i am having trouble keeping theese in place though..they just slip off by the time i get the pipes connected. anyway of keeping them in place? because the cylinder heads are facing pretty much downwards the gaskets keeps on falling down :P
Deviant400
part numbers
18291-mr8-0000 x2
18291-216-0000 x4
yeah can be a bit fiddly offer up the pipe and slot them in before shoving the pipe in the hole :grin:
xivlia
Post by xivlia »
i didnt quite understand what you meant by offer up the pipe :D
Deviant400
i just offer up the pipe so its almost connected then slot the gasket in ,
xivlia
Post by xivlia »
ahh oaky :D i get what you mean now. yeah i tried that but its limited space in the rear manifold :\. il try again tomorrow when i can actually be bothered to do it :D you think i could maybe use some heavy oil to make it stick on it? obviously it has to be non flammable oil! :D
Deviant400
yeah rear manifold to cylinder head , they can be a pain to slot in , just gotta keep trying, mine was easy as i didnt have the rear shock or swingarm in the way when i fitted the manafold
xivlia
Post by xivlia »
hunter
Post by hunter »
xivlia wrote:hmm okay. itl probably be fine...i am having trouble keeping theese in place though..they just slip off by the time i get the pipes connected. anyway of keeping them in place? because the cylinder heads are facing pretty much downwards the gaskets keeps on falling down :P
use a dab of silicon mastic, or a dab of grease push the seal in the exhaust port it will hold the seal in place for you to put the pipes in.
xivlia
Post by xivlia »
ahh okay :D il put some grease to hold it in place then :D
Locked
