Page 14 of 27
				Posted: Wed Jun 15, 2011 9:28 pm
				by porndoguk
				Got any left over?
this was copied from an earlier post in march,
This is Tonight
With thanks to Variable Valves Suck for the Fiber Glass,
as you may remember the carbon was only one layer and quite thin and flexible, and needed reenforcement so i can get a high gloss finish.
anyway 2 a4ish sheets of fiber glass and used the off cuts as ribs across and hey presto its ROCK solid
its now siliconed on, and will get the expanding foan in it tomorrow morning before i start work, so then it will hopefully be dry by tea time so i can W&D and get a layer of laquer on.
				Posted: Wed Jun 15, 2011 9:31 pm
				by Delboy
				Yep, your more than welcome to it
				Posted: Wed Jun 15, 2011 9:37 pm
				by porndoguk
				vfrderek wrote:Yep, your more than welcome to it
Cheers Del,
you popping by tomorrow?
				Posted: Wed Jun 15, 2011 9:39 pm
				by Delboy
				Can do Rick, I'll pop in after work
				Posted: Wed Jun 15, 2011 9:41 pm
				by porndoguk
				vfrderek wrote:Can do Rick, I'll pop in after work
Top man cheers buddy, what did you use to polish the laquer btw?
				Posted: Wed Jun 15, 2011 10:11 pm
				by Delboy
				Used a rubbing/cutting compound from Halfords bud
				Posted: Wed Jun 15, 2011 10:32 pm
				by porndoguk
				vfrderek wrote:Used a rubbing/cutting compound from Halfords bud
can i borrow that too please, i need to sort my self out painting wise now ive fixed the compressor
				Posted: Thu Jun 16, 2011 6:32 pm
				by porndoguk
				More Pillion Carbon Pod work,
its all dryish underneath, foam is a bit sticky, but will dry out over night, the shell its self is pretty tough now, so wet and dried it,
ive also dug out the brackets that hold it in place on the bike which i had powder coated gloss black,
then i used some alcohol to make sure theres now grease on the seat and put the first layer of laquer on, ive not done an amazing job to be honest as its so hard to spray carbon with the interwoven layers, its kinda hard to follow the surface with you eyes, but ill wet and dry this nice and level tomorrow evening,
its on a heat matt so should cure nicely. will update again tomorrow evening.
				Posted: Thu Jun 16, 2011 8:02 pm
				by BillingCBR
				how much to make me one mister? :mrgeen:
				Posted: Thu Jun 16, 2011 8:04 pm
				by Delboy
				Just seen Rick's latest updates in the metal and it is looking MINT! Pics dont do the detailing justice, this bike just gets better!
Well done Rick, keep it up buddy.
