Porndoguk's SEED NC30
porndoguk
Post by porndoguk »
Got any left over?
this was copied from an earlier post in march,
Carbon Fiber Seat Cowl - Work in Progress
This is Tonight
With thanks to Variable Valves Suck for the Fiber Glass,
as you may remember the carbon was only one layer and quite thin and flexible, and needed reenforcement so i can get a high gloss finish.
anyway 2 a4ish sheets of fiber glass and used the off cuts as ribs across and hey presto its ROCK solid
its now siliconed on, and will get the expanding foan in it tomorrow morning before i start work, so then it will hopefully be dry by tea time so i can W&D and get a layer of laquer on.
Delboy
Post by Delboy »
Yep, your more than welcome to it ;-)
porndoguk
Post by porndoguk »
vfrderek wrote:Yep, your more than welcome to it ;-)
Cheers Del,
you popping by tomorrow?
Delboy
Post by Delboy »
Can do Rick, I'll pop in after work
porndoguk
Post by porndoguk »
vfrderek wrote:Can do Rick, I'll pop in after work
Top man cheers buddy, what did you use to polish the laquer btw?
Delboy
Post by Delboy »
Used a rubbing/cutting compound from Halfords bud
porndoguk
Post by porndoguk »
vfrderek wrote:Used a rubbing/cutting compound from Halfords bud
can i borrow that too please, i need to sort my self out painting wise now ive fixed the compressor
porndoguk
Post by porndoguk »
More Pillion Carbon Pod work,
its all dryish underneath, foam is a bit sticky, but will dry out over night, the shell its self is pretty tough now, so wet and dried it,
ive also dug out the brackets that hold it in place on the bike which i had powder coated gloss black,
then i used some alcohol to make sure theres now grease on the seat and put the first layer of laquer on, ive not done an amazing job to be honest as its so hard to spray carbon with the interwoven layers, its kinda hard to follow the surface with you eyes, but ill wet and dry this nice and level tomorrow evening,
its on a heat matt so should cure nicely. will update again tomorrow evening.
BillingCBR
Post by BillingCBR »
how much to make me one mister? :mrgeen:
Delboy
Post by Delboy »
Just seen Rick's latest updates in the metal and it is looking MINT! Pics dont do the detailing justice, this bike just gets better!
Well done Rick, keep it up buddy.
