Page 13 of 112
Re: Cannot get Rear cylinder header pipes out...
Posted: Sun Oct 16, 2011 6:05 am
xivlia wrote:stubby? the manifold?, becuse its got a snaped screw..i took it off only to find out the damn screw is welded on from the behind...so its going in the bin and i bought a new one...for a 10ner :P
Oh right, i remember, you broke one of the studs off while removing the exhaust.
Be careful with the next one..
Posted: Sun Oct 16, 2011 3:30 pm
by xivlia
yep broke one :( and i will be very careful next time :D but people learn by mistakes :P
Posted: Sun Oct 16, 2011 7:03 pm
by xivlia
just a quick question...do i have to put seals on where the manifold connects? i know you put seals on where the downpipe connects to the manifold..but do i need to put some were the manifold connects to the engine?
Posted: Sun Oct 16, 2011 7:05 pm
by Drunkn Munky
Yes if by seals you mean gaskets
Posted: Sun Oct 16, 2011 8:17 pm
by xivlia
woops yeah i meant gasketts sorry.. oh ok il need to buy two more then, looks like there wasnt any in there either...the previous owner realy fucked this bike up. shouldnt of bought this without MOT..big mistake
Rear wheel turning Stiff at some points?
Posted: Mon Oct 17, 2011 10:11 pm
by xivlia
okay. so i have a stripped speedo drive cog. (the white plastic part) and im starting to think it got stripped due to my rear wheel turning very stiffly at some points... here is how i tested... i stuck a 13 or 14mm hex socket into the speedo drive....and started turning it witht he wrench...it turns freely but at some point it would start to get very stiff..and then free itself again and so forth..it would do this in a loop. im thinking at the stiff point the cog started to strip and eventually stopped working..... what could be the cause of this stiffness at somepoints? the chain? sprockets? anything else? cheers guys
Re: Rear wheel turning Stiff at some points?
Posted: Mon Oct 17, 2011 10:15 pm
by Drunkn Munky
Does the chain go tight at the stiff points? if so then theres your answer, if not then i suspect the hub being the problem. Cant see it stripping a speedo drive tho
Posted: Mon Oct 17, 2011 10:19 pm
by xivlia
hmm i havent checked the chain..il try it tomorrow. i dont know i thought it could of caused the plastic drive to strip as it gets stif more force is acting on the plastic drive and then the speedo cable starts to dig itself in and eventually strips.
Posted: Mon Oct 17, 2011 10:21 pm
by Drunkn Munky
Na i doubt it, the bolt turns the plastic drive not the other way round so theres no resistance against it.
Posted: Mon Oct 17, 2011 10:28 pm
by xivlia
oh i suppose. :P
