Page 13 of 29
Re: Svedberg's RVF Race bike
Posted: Mon Dec 27, 2010 12:35 am
by L.Svedberg
Hi there Ronni!
You may well be correct about the stiffness issue. I would suspect if there's a negative effect from this, it would be very minor. Might as well be an even better stiffness than before, what do I know? On the other hand, the modiffied SP2 swingarm is way lighter than the standard NC one, which is good, no doubt.
Plus, as everyone knows; if it looks fast, it sure as hell is, indeed, fast
Posted: Tue Feb 01, 2011 9:27 pm
by mruehl34
Any news?
Michael
Posted: Wed Feb 02, 2011 11:57 pm
by L.Svedberg
Hi Michael!
No real news, I'm fabricating the linkage mounting lugs for the sp2 swingarm now, and there's some welding still to be made on it as well.
Great stuff with your FI project! Is it running yet?
Cheers/
Lasse
Posted: Sat Feb 05, 2011 6:41 pm
by L.Svedberg
Finished welding the linkage mounts yesterday, and the swing arm is now on the bike! Still some milling to be made on the linkage itself to get correct axial clearance, as the whole shock/linkage assembly needs to be moved a bit to the right in order for the shock spring to clear the swing arm. no big deal, just another small issue. Rear wheel alignment is roughly made so far, and next I'll have a pair of lasers attached to be spot-on centered.
A front y-spoke PVM mag wheel is also headed my way to accompany the rear wheel.
Posted: Sat Feb 05, 2011 8:37 pm
by mruehl34
Lasse
piiiiiiiiics pls.
Michael
Posted: Fri Feb 18, 2011 8:22 pm
by L.Svedberg
Posted: Fri Feb 18, 2011 8:58 pm
by ChowderV4
That is just crazy sexy!
wish i could see it in the flesh.
Posted: Fri Feb 18, 2011 9:15 pm
by L.Svedberg
Is it only me, or why ain't the pics showing like they use to?
/Lasse
Posted: Fri Feb 18, 2011 9:16 pm
by alexwitham
I also cannot see the pics.
Posted: Fri Feb 18, 2011 9:22 pm
by Drunkn Munky
You've copied the wrong tags over lasse.
Top work by the way
