Svedberg's RVF Race bike
L.Svedberg
Re: Svedberg's RVF Race bike
Post by L.Svedberg »
Hi there Ronni!
You may well be correct about the stiffness issue. I would suspect if there's a negative effect from this, it would be very minor. Might as well be an even better stiffness than before, what do I know? On the other hand, the modiffied SP2 swingarm is way lighter than the standard NC one, which is good, no doubt.
Plus, as everyone knows; if it looks fast, it sure as hell is, indeed, fast ;)
mruehl34
Post by mruehl34 »
Any news?
Michael
L.Svedberg
Hi Michael!
No real news, I'm fabricating the linkage mounting lugs for the sp2 swingarm now, and there's some welding still to be made on it as well.
Great stuff with your FI project! Is it running yet?
Cheers/
Lasse
L.Svedberg
Finished welding the linkage mounts yesterday, and the swing arm is now on the bike! Still some milling to be made on the linkage itself to get correct axial clearance, as the whole shock/linkage assembly needs to be moved a bit to the right in order for the shock spring to clear the swing arm. no big deal, just another small issue. Rear wheel alignment is roughly made so far, and next I'll have a pair of lasers attached to be spot-on centered.
A front y-spoke PVM mag wheel is also headed my way to accompany the rear wheel.
mruehl34
Post by mruehl34 »
Lasse
piiiiiiiiics pls. :grin:
Michael
ChowderV4
Bike owned: 94 Fzr 400 3TJ ZXR400 Racer
Post by ChowderV4 »
That is just crazy sexy!
wish i could see it in the flesh.
L.Svedberg
Is it only me, or why ain't the pics showing like they use to?
/Lasse
alexwitham
Bike owned: 675R, GSXR6, NC30
Post by alexwitham »
I also cannot see the pics.
You've copied the wrong tags over lasse.
Top work by the way
