Page 12 of 49
Re: VFR400 rebuild
Posted: Thu Apr 14, 2011 5:09 pm
by porndoguk
lizard821000 wrote:fk me, lol bearing popped straight out with ease. winner!! brand spanky new koyo ones......i called rick o too and he s hooked me up with some new bearings and also gave me info to reconize if my forks already have his kit or not, so cheers rick o if your out there . still ne joy with the 46mm nut though
how essentual is it to undo!? id like to atleast inspect the bearings while its apart but what about things like changing over the sprockets/chain etc....and caliper.....can i do all that without touching the huge nut??
cheers lads.
shaun
That nut only needs to come off if you wanna change the brake disc or bearings.
the sprocket can be taken off without removing it pal.
what did rick say about recognising the differences?
Re: VFR400 rebuild
Posted: Thu Apr 14, 2011 5:47 pm
by lizard821000
well that good and bad new then really!?? hmmm, i d like to atleast inspect them but i suppose i could put the wheel back on and cheack for play.....
so rick,
he said the old springs arnt sermetrical all the way down but springs get closer toward the middles..... so wide up top,closer in middle and wide again at bottoms, the new upgrade springs are like normal ones and the gaps are the same all the way down, also, his spacers are aluminium 140mm ones and the old use steal 150mm.
just popped down to my uncles too and had the tyres taken off, he checked both tyres cos the rear had a slow puncher but found it was the valve and he said theres a good couple of thou miles left on them too, so saving pennies for now!! sweet!
graham from jap4 got the nice shiney black billet tyga levers too me too! winner!! they look and feel real nice too. he sent me the new screen and mirrors few weeks back cos the levers wernt in but when i got the levers yesterday he had sent me another set of mirrors and a screen lol i guess the mans busy and forgot he had already, so i need to send those back over weekend to him lol cheers for the levers anyways graham, there spot on!!
well, there s not much more i can do till the wheels are done apart from check and rebuild my forks.....mirrors ,screen, levers and lines etc are easier to do ones she s a rolling bike again.......spose i can do the new sprockets over the weekend and chain. oh, and clean calipers and change my pads over .
bought a solder iron too to just fix up some cracks on the pannels too.....so suppose there s plenty to do really lol. ill get some pics up tonight of how she looks and just eye candy for all you nc30 whores lol
cheers guys!!
all lugs broke
seat was held on with cable ties round the sub frame lol
cheers ricky for the yokes, as you can see, mine are/where a mess :)
Re: VFR400 rebuild
Posted: Thu Apr 14, 2011 6:34 pm
by porndoguk
looking good,
took a bad time to start a rebuild
get out on it shaun!
you have PM
Re: VFR400 rebuild
Posted: Thu Apr 14, 2011 6:42 pm
by lizard821000
cheers dog, im not fussed pal, i have a little mito to piss around on over the summer, anyways, the work im doing shouldnt take long.
Re: VFR400 rebuild
Posted: Thu Apr 14, 2011 7:28 pm
by hardnutdvd
while u got the front end in bits are you planning any work on the rads.. they look like they could do with the toothbrush treatment..
things should progress nicely when ya got all ya bits to hand
Re: VFR400 rebuild
Posted: Thu Apr 14, 2011 7:41 pm
by lizard821000
im gunna try clean it up a bit yeah, its a state..... im trying not to get sucked into doing too much tbh, lol, its too tempting to refurb the lot, like the mito but i really just want it as my hack. yeah thing should come together pal when everything ready to fit.... just hate the waiting inbetween and also trying to find the time.
Re: VFR400 rebuild
Posted: Thu Apr 14, 2011 8:26 pm
by porndoguk
Re: VFR400 rebuild
Posted: Thu Apr 14, 2011 8:34 pm
by lizard821000
lol, na. i payed pennies for her rick and wanted a honda for reliability too....so when it come along it was perfect for my needs.
the mitos just too temprimental as a hack, plus its sex lol
alright, she ll be a good looking hack.
Re: VFR400 rebuild
Posted: Sat Apr 16, 2011 6:23 pm
by lizard821000
well, didnt quite go to plan today....spend half the day in and out up the shops etc to get desired tools for the job. separated as much of the forks as i could but cant split them completely!! little fkers are a b*st*rd to pull apart. ill try again tommorrow , given in for today! im gunna try and tie some weights to the bottom part of the forks them use the hammer slide effect to separate. iv been trying for about an hour with no luck.
didnt even touch the sprockets today either
lol
found a pipe wrench handy mind to undo the top fork nut, also, are my old 89 model forks adjustable?? i have a screw inside the main top nut which i can turn!?
cheers lads.
oh! and i found out i dont have the rick o upgrade kit fitted , so this week ill be ordering that up too. just to confirm, will i need new dust and oil seals , im guessing yes and ill have to inspect the bushings but is it good messure to replace the lot while its all out!?
cheers
Re: VFR400 rebuild
Posted: Sat Apr 16, 2011 8:49 pm
by Man_Named_Dave
lizard821000 wrote:well, didnt quite go to plan today....spend half the day in and out up the shops etc to get desired tools for the job. separated as much of the forks as i could but cant split them completely!! little fkers are a b*st*rd to pull apart. ill try again tommorrow , given in for today! im gunna try and tie some weights to the bottom part of the forks them use the hammer slide effect to separate. iv been trying for about an hour with no luck.
lol
cheers lads.
cheers
K Model forks are not adjustable.
