the project completed! (not for 56k!)
- RVFHooligan
Re: the project begins! its alive! (not for 56k!)
Must be those secret HRC race cams! lumpity lumpity lope.yayoboy wrote:thanks jeff :D , any ideas on the unsmooth tickover or am i just paranoid?!?
It would seem that it would have to be a problem with the carbs? Seems like it is surging and racing then slowing back down. A heart arythmia I suppose, get her to a cardiologist or lay off the caffeine.
My Sponsor?  MasterCard, I only wish it was priceless!
						- yayoboy
lol! i wish, gonna have a try a balancing the carbs i thinkRVFHooligan wrote:Must be those secret HRC race cams! lumpity lumpity lope.
						- yayoboy
mines a 91, i thought also b4 the rebuild 'that badge will look great polished' but when i got it off found it was plasticSpike16 wrote:really? what year is your bike? mines metal i thing and my bikes a 1990
that said yours could be different, i wouldnt know for sure
				dix
Re: the project begins! new pics
dood im really trying to do this whats the secret im strugglingyayoboy wrote:almost finished frame
after doin this i look like ive just come out of a coal mine!!!! lol!
looks awsome but ive think i have already said that about 5 times already
- yayoboy
its not easy m8, and bear in mind it takes DAYS toget that type of finish, just warning ya before you try and do what i did.... theres no goin back....dix wrote:dood im really trying to do this whats the secret im struggling
but if ya wanna try you need a d/a sander, but you might get away with an electric palm sander etc. you need this to sand of what i think is the anodised layer of the frame, it takes ages and it goes shitty lookin all over but once it goes back to bare ally you can start sandin it up thru the grits, ie p240 up to p3000 (wet). then get yourself a polishin mop and some autosol metal polish to bring in that mirror finish!
hope this helps, but like i say, its a bitch to do and i hated it! but on the other hand the finish is worth it imo, even if i have to polish every week to keep the shine!
				Spike16
im polishing my exhaust bracket at the mo but cant get rid of the pitting, iv sanded with wet an dry and that worked a bit but now iv started polishing its gettin really nice but still with loads of pitt holes, what your advice
				Carlos
You could use oven cleaning gel or spray, anything with sodium hydroxide as an active ingredient, this will eat through anodising but be carefull not to leave it on too long as it will eat into alloy too, apply a little and rinse off, take a look and continue. goggles, mask and gloves are a must. still a crappy job but saves a little time. Like Yayo says, once you start there's no going back, beware.dix wrote:
dood im really trying to do this whats the secret im struggling![]()
				zimm
 - Bike owned: some ZXR400's, ty175, mz ts125
or get it aqua blasted, then you are starting with an almost polished bare alloy surface, and its easy :)
i had my polished frame powdercoated though..
cos im lazy and anything polished on my bike will end up white and furry.
- yayoboy
keep sanding!Spike16 wrote:im polishing my exhaust bracket at the mo but cant get rid of the pitting, iv sanded with wet an dry and that worked a bit but now iv started polishing its gettin really nice but still with loads of pitt holes, what your advice
						- yayoboy
ok, today did alot of work on the carbs, balancing, drilling slides, setting float heights, pilaot screws....
but it was really worth it the bike ticks over sweet now and revs better too :D !
also started bleeding the sp1 calipers, which is provin to be a bit of a pig, im sure i had an hrc banjo bleeder around ill try an dig it out to make life easier tomorrow
