Page 11 of 23
Re: Banoffee's NC30
Posted: Sat Mar 13, 2010 5:44 pm
by banoffee
57.3, yep hit the limiter a few times.
Re: Banoffee's NC30
Posted: Sat Mar 13, 2010 6:41 pm
by ibby4585
Not bad, reckon you could raise that limiter a bit for a few more hp!!
Re: Banoffee's NC30
Posted: Sat Mar 13, 2010 6:42 pm
by banoffee
I've been wondering about that...
Re: Banoffee's NC30
Posted: Sat Mar 13, 2010 6:44 pm
by ibby4585
Didn't you set the red line 14000 on the HRC module? Might be worth raising it a bit, but hey your never gonna do that on the road are you!!
Re: Banoffee's NC30
Posted: Sat Mar 13, 2010 6:52 pm
by banoffee
I set it to 14,500 to be safe although it goes past that on the tacho. How accurate/otherwise are they? (the stocko tacho)
Also, what's the stock redline?
Re: Banoffee's NC30
Posted: Sun Mar 14, 2010 7:01 pm
by banoffee
Trying to source a K&N air filter to try as think it might be running a tad rich with the baffle in and I get paranoid without one! Going to try the HRC -2 ignition map sometime soon too.
A broken speedo cable on the way back from Gibsons this weekend prompted some fairing-off OCD action. Have been out several times on shitty roads recently so was about time...
Re: Banoffee's NC30
Posted: Thu Mar 18, 2010 5:36 pm
by banoffee
Have ordered a new speedo cable and picked up a K&N filter to experiment with. A couple of recent pics...
Am going to upload the HRC -2' map and fiddle about with synching the tacho with the programmable CDI too as it appears to be out.
Re: Banoffee's NC30
Posted: Sun Mar 21, 2010 11:12 am
by banoffee
New speedo cable fitted, HRC -2 map uploaded and made a -5% adjustment to the tacho output. Also replaced a few more manky fasteners with stainless goodness.
Just waiting on the K&N to arrive so can clean, oil and fit it then put back together for a test ride.
Re: Banoffee's NC30
Posted: Sun Mar 21, 2010 7:58 pm
by banoffee
Re: Banoffee's NC30
Posted: Fri Mar 26, 2010 5:41 pm
by banoffee
Have been busy working on another bike, however K&N has been re-sealed, cleaned and oiled. Finger pulled out of arse to put the NC30 back together over the weekend
Oh - new smilies...
