600 suspension thread ...again!
PARUS
missinNZ
Re: 600 suspension thread ...again!
finally got round to uploading.chrisja2 wrote:A pic speaks a thousand wordsIm interested to see this anyway. Do you mean the coolant res?
Chris.
the ass is sitting very high as the eye to eye measurements went from 290 to 330mm, yes the air intake doesn't fit snug!
loooking from the inside, didnt know if its the done/right thing but shock is upside down?
both side of the fairing had to be shortened to accommodate wheel, as well as 1 link being removed.
chicken line, who says it gets bigger on a 160. she does drop in a little faster but have hardened up the front also to compensate, but i run a 120/60 front so it went in pretty quick (sometimes a bit too) to start.
PARUS
I had set up FOX Racing shock from CBR600F2.
No any problems not with fairing, nor with coolant reservoir. My eye to eye measurement is 310-320mm.
Which shock do you use ?
missinNZ
missinNZ wrote:ive managed to fit a 02' 600rr shock into the ass end with a 8mm int 10mm ext bushing on the lower and shimmed the top end. followed someone elses thread with regard to using a dremil on the linkage to give space for spring........but there aint enough space for the coolant.
advice please.....?
- chrisja2
- Bike owned: nc29 trackbike
Im guessing the big question is does it handle better? With the back end higher is it stable at higher speeds? Is it that much an improvement on a cbr600 shock? Looks nice though, nice to see a bit of experimentation lol.
Chris.
Chris.
missinNZ
have had it upto 100mph, not too bad. i have a damper that im looking at fitting to calm down the front. makes the ride much smoother on the rubbish isle of wight roads and it was hard to pass up £25 inc post after i sent an email to an ended item off of ebay (no bids). it has made the front start lifting on quick acc tho.
greggo
Interesting, I'll measure my race shock when I get the bike back as I tend to have the rear quite high on that bike too. Might make a good alternative to getting another standard shock modified.
Missin, I'm not too sure what you mean by
don't suppose you have a picture?8mm int 10mm ext bushing on the lower and shimmed the top end
missinNZ
on the lower eye the std rr shock takes a 10mm (12mm?) cant remember and the 29 std was smaller. it was a case of getting a mate to machine me up a little tube (bush) to make the eye 'smaller' making sure metal composites/types not different and the 29 std bolt fit nice and snug. the top eye is alright but a very thin shim (same as above but very thin) to bulk out and a little angle grinding (to make horizontal eye narrower) on the top is needed too. cant take pics without taking it all out. did take a few weekends to do as these problems only arise as you sort one out another arose. using an engine hoist is the best as when you come to put it in moving up and down is easier and necessary to align the lower eye bolt through the hole in frame.
