Help please loss of power and then cut out
fastdruid
Regular Member
Re: Help please loss of power and then cut out
Post by fastdruid »
jo wrote:sounds like you have the same problem as I had last night :cry: these NC30 electrics are a bastard :cry:
Some of the issues are due to modifications, for example using 60/55 bulbs in the NC35[1], the UK NC30 has a second relay for the low-beam, the domestic version doesn't and if you run the easy to get 60/55's with the tabs snipped off instead of the hard to get (IIRC) 60/35's the hi/low switch melts and packs up.
The reg/rec is a common failing on *lots* of bikes, hardly just the NC. For example Suzuki had a period of unreliable reg/recs (GSX's), the 'fix' was to use a Honda (superdream) one....
Druid
[1] And probably the NC30.
jamieducati
Post by jamieducati »
My 30 did this today. checked voltage stationary and then running - 12 v for both. Swapped to spare rectifryer and then voltage differences appeared as expected.
I would try another rectifier before any thing else.
Benc30
Post by Benc30 »
cheers fella, when you say stationary do you mean engine off, and then running at idle?
jamieducati
yes stationary meaning ignition and lights etc off. (12v) . When I started it I had the same, even when revving engine.
New rectifier fitted and engine running would respond to revs by increasing the voltage slightly.
Benc30
Post by Benc30 »
Well kinda good news..
stuck a meter on the bike and got 12.4 volts off and 12.8 running at idle...
revved it to 5k and got 13v
So im gonna order a new regulator and keep everything crossed...
cheers for all your help so far! :mrgreen:
Also is that electrex world a good place to buy or is there cheaper???
worked out at 74 quid with postage??
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
my money is on the stator windings being goosed....the fact that the battery is getting a charge indicates that reg rec is working but its a low charge......same thing with mine and it was a fecked alternator.you should do the alternator test to be sure before blowing money on a reg rec
Benc30
Post by Benc30 »
fair enough mate ill check it out. 8-)
Benc30
Post by Benc30 »
Well went to check my alternator today removed the seat to get to the reg/rec plug pulled back the rubber boot on the plug to find a loose connection.... :lol:
repaired and its back up to 14.8 volts again.. :D
thanks for all your advise folks.
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
good find mate...... :D :D
Benc30
Post by Benc30 »
Im chuffed as nuts, alternator shouldnt fail really the bikes only done 8000 miles :lol:
