Page 2 of 2
Re: NC30 front forks PLEASE HELP!!
Posted: Mon Nov 09, 2009 7:10 pm
by Freekazoid
i really know how to drag out this fork oil seal thing. . .
prob is was looking on evilbay for what price the seals go for on there & then came to the conclusion maybe i have the wrong size fork oil seals?
if so why is it that only the one side would leak?? when i phone my local shop they said i need the Ariete ARI. 047 that is what i have on at the moment but now i'm not sure if they are right for the bike? any help???
Posted: Mon Nov 09, 2009 11:40 pm
by RickOliver
To reiterate the previously made point -
Use Genuine Honda Seals...!
51490-MN8-305
Should be readily available from your local dealer as they also fit CBRs VFRs and all sorts of other models.
Rick
Posted: Tue Nov 10, 2009 12:21 am
as said before, they probably bad quality, damged when instlaling, or have pitted / scratched fork tubes.
make sure forks are clean and not scratched or pitted and use the proper honday seal.. will last many years if installed properly
Posted: Tue Nov 10, 2009 10:06 am
by Freekazoid
ok that is fine i just need to make sure that i get the right part numbers as it seems that the dealers here actually have no clue what the correct parts are for the bike.
Posted: Wed Dec 30, 2009 12:35 pm
by Freekazoid
ok so i did the deed the otherday replaced the fork seals. went on a couple of awesome runs 600km put on the clock, & again the same 1 seal is leaking, so i reckon that the shaft of the shock is damaged. so if this is correct what would you guys recommend? is it posible to fix this? how? any help, much appreiated.
