3TJ Gearing
Re: 3TJ Gearing
Hi all
I now have a gearing chart I can email.
Anyone who wants one let me know your email addy and I will send it through.
Dobbs
Dobbs
Re: 3TJ Gearing
hi m8 could i have a copy please email is d3ddubs@hotmail.co.uk big thank u cheers daz
- Bike owned: fzr600-,yzf750-,owo1,750
Re: 3TJ Gearing
i will have a copy please; markastbury@hotmail.co.uk cheers
- Motorcycle Solutions
- cagiva996
Re: 3TJ Gearing
me too please! im at pulseiow@tiscali.co.uk
many thanks-steve
many thanks-steve
Re: 3TJ Gearing
Emails sent chaps I hope it helps,
I've used it myself for the SP gearbox and it seems spot on,
Not sure about the 160+ MPH top speed estimates though!
Re: 3TJ Gearing
TOP MAN !!!
Re: 3TJ Gearing
I know it's dragging up an old post, but do you still have the gearing info? If so can you either post it up or mail me nickandsharon@virginmedia.comdobbslc wrote:Sorry I haven't got back to you guys I've been busy at work, I'll dig out the paperwork & post it here as soon as I can.
Ta
Re: 3TJ Gearing
Whilst dragging this up, i have another query.......
I'm planning on converting to 520 for the track for ease of sprocket swapping etc........
But, when checking out what i need i've noticed that the standard setup is 428 (130 links) with 19/55 sprocket sizes whereas the 520 conversion is only 104 links and uses 15/43 sprocket sizes.
Question is why the big difference in the sprocket sizes (final drive ratio is almost the same for both setups) and chain length?
Am i just missing the obvious? My concern is that the chain will run a lot closer to the swingarm with the 520 conversion. Is this the case?
HELP
HELP
Re: 3TJ Gearing
the 520 is no problem as long as you dont go mega small on the front.
15/43 is 2.87 (divide biggest by smallest)
19/55 is 2.89 so they're pretty close! there used to be a good link on the wemoto site but it doesnt appear to work now! it has the info on the higher numbers being better accel or top end ( i cant remember!)
edit: this bit!
Lowering the ratio increases top end speed - Increasing the ratio increases acceleration and bottom end
edit: this bit!
