Page 2 of 7
Re: nc35 tidy up
Posted: Wed May 19, 2021 4:11 pm
by sand380
new subframe fitted. excellent value for money.
having to fit a full new wiring loom 80 percent of multiplug have been changed to bullet connectors lol
clearly the previous owner was trying to locate a wiring issue .
one of the only plugs that hadn't been changed was the 2 wires from the pick up.1 of these were broken.
thankfully I have lots of old honda looms to borrow the correct plugs. just a case of fitting new pins to most the wires.
Re: nc35 tidy up
Posted: Wed May 19, 2021 4:14 pm
by sand380
everything back from the platers . all looks like new
upload and share images
Re: nc35 tidy up
Posted: Wed May 19, 2021 4:45 pm
by sand380
CMSMJ1 wrote: Tue May 18, 2021 9:54 am Good to see it getting a new lease of life :)
414 kits would give you approx 5hp - according to the Gforce guys who sorted all that out - have a read on here if you want to get into it
https://mngforce.typepad.com/nc450vdev/ ... -kits.html
I remember Mike's site and dreamed of building one when I had my last nc30 about 20 years ago!
if it gets anywhere near 70hp I'll be happy :)
at some point I'll pull the motor and refresh it however I have a aprilia rs250 with a 350cc stroker and cylinder kit which is currently bleeding me dry
Re: nc35 tidy up
Posted: Thu May 20, 2021 10:52 pm
by sand380
made some headway. valve clearances adjusted so all healthy and in spec. so easy with no cam chain getting in the way!
washed all the covers down and dried them off with compressed air. at first glance this seemed unnecessary. only when you looked carefully in the nooks and corners you see all the grit left over so be warned when having blasting done.
cam covers on. clutch cover too.
hit a problem with the wiring loom. my replacement loom is from a Japanese bike. my bike is a uk bike.
Haynes manual is correct for my bike but not for my replacement loom.... great!
after 2 coffees and 3 cigarettes later we now know where everything is going. I think
https://ibb.co/c8WfQz4
Re: nc35 tidy up
Posted: Thu May 20, 2021 10:53 pm
by sand380
Re: nc35 tidy up
Posted: Fri May 21, 2021 4:01 pm
by MadMotoUK
Wiring loom shouldn't be too different, just remember that JDM bikes of the period had permanent running lights and lower wattage headlamps. You may want to add a relay or two for the headlights if you're planning on running 55/60w halogens, otherwise stick to 35/35w or fit LED.
Re: nc35 tidy up
Posted: Sat May 22, 2021 2:45 pm
by sand380
thanks, I had wondered why there was 3 wires to the indicators which certainly explains that 👍
Re: nc35 tidy up
Posted: Sat May 22, 2021 10:24 pm
by sand380
linkage and swingarm bearings replaced.
frame was given a quick clean with some alloy wheel cleaner. it's great stuff but you would want to leave it on too long. any more than 5 minutes makes a right mess as it reacts with the aluminium.
all the powdercoated parts have had the masking tape removed which is a bloody job in itself lol
Re: nc35 tidy up
Posted: Sat May 22, 2021 10:26 pm
by sand380
I noticed my dogbone part of the linkage is more like a m11 rather than a m10 so this will need replacement. is this a common problem on these?
Re: nc35 tidy up
Posted: Sun May 23, 2021 8:13 am
by MadMotoUK
M11? I've never seen an M11 thread on a motorbike. Are you sure it's not M12? Remember that Japanese hex sizes are smaller than EU. An M12 nut will need an 18mm spanner, an M10 nut will need a 16mm spanner, as opposed to 19mm and 17mm respectively in EU sizes.
