Page 2 of 2
Re: Threads in plug hole are gone!
Posted: Sat Dec 13, 2008 9:56 pm
by zimm
sod easy-outs .. chances are it'll just snap ..
get a big torx bit (splined) and tap it into the remainder of the plug, then unscrew. simple.
had it happen a couple of times on a zxr
Posted: Sat Dec 13, 2008 10:10 pm
by brooky
ive done it before with an eziout but due to the depth of the plug hole you will need to weld it to a socket, dont even need the engine out the bike that way. Try it first if it fails i have a spare head.
Posted: Sat Dec 13, 2008 11:46 pm
by Waza4
Ask around a few local engineering shops.
Posted: Sun Dec 14, 2008 4:21 pm
by scoops
I got a lad up to have a look at it today, he welded a bit onto an easy out and got the bit of the plug out. Threads are grand!! Im a lucky Git!!!
Cheers for advise and tips guys
Posted: Mon Dec 15, 2008 8:49 am
by Dumbledore Calrisian
Seeing as i'm a retarded moron, it looks like i've done the same thing. Sheared the head of my spark plug off inside the head. Will be welding up a tool tomorrow at work and see how i go.
Will let you know if god hates idiots tomrrow.
Posted: Mon Dec 15, 2008 12:12 pm
by zimm
big torx bit in a socket with an extension eliminates all this welding malarky !
just a thought ;)
Posted: Wed Dec 17, 2008 6:57 am
As luck would have it, god loves a retard. Welded up a screw extractor to a bolt and got the head of the spark plug out, new one in, purs like a kitten.
I'll post up picks of my shitty welding tomorrow,
would also like to add, that at $19 wholesale, this is the most expensive spark plug on the planet this side of the iridium range.
wtf?
what were honda thinking when they created a motor that needed such a unique spark plug that it doesn't fit anythign else?!?
Posted: Wed Dec 17, 2008 7:26 am
Dumbledore Calrisian wrote: would also like to add, that at $19 wholesale, this is the most expensive spark plug on the planet this side of the iridium range.
wtf?
Ahh..but it fits the NR750 too. :ugeek:
Only the best and smallest plugs for the mighty V4 8-)
