Page 2 of 3
Re: NC30 / NC35 Derestriction and 5000RPM misfire
Posted: Thu Jan 01, 2009 4:12 pm
by 1990nc30
What i'm saying is, before it was fitted it would reach 193kph (120mph) and with it fitted it would still only reach 120mph!
Posted: Thu Jan 01, 2009 4:16 pm
by wullvfr
yeah but this time instead of it reading 193kph this time it is reaching 120kph...both being the same speed but with the converter being fitted its mph instead of kph..........
i can't understand why it would do that at all...makes no sense!!!the restriction should never kick in now at all because the switch is never triggered.
william
Posted: Thu Jan 01, 2009 4:32 pm
by 1990nc30
Yeah sorry mate that's it, i'm a bit thick today after last night lol!
It is very strange, it must be some sort of restriction somewhere.
Posted: Fri Jan 02, 2009 5:28 pm
It could be thats all your bike will do.
Due to several possible things.
-Change in gearing
-Poor maintainance (valve clearances / plugs / air filter)
-Other non-standard modifications having a detrimental effect. (airbox in particular)
Do you really need to go faster than circa 120mph anyway?
Posted: Fri Jan 09, 2009 10:19 pm
by Dumbledore Calrisian
Any chance we could have those pics posted re where to insert the resistor?
Would like to do this as was mildly miffed when enginge started cutting out at speed!
Posted: Sun Jan 11, 2009 1:37 am
by RVFHooligan
Here's a pic for those who have not seen the inside of the speedo. Bend the tab (#2) so it doesn't contact the wheel (#1).
Posted: Sat Jan 31, 2009 12:16 am
by Honda_NC35
so if u have an HRC cdi, this 180kph problem is solved?
u dont need to open ur speedo panel?
Posted: Sat Jan 31, 2009 9:43 pm
by wullvfr
Honda_NC35 wrote:so if u have an HRC cdi, this 180kph problem is solved?
correct.........
hrc cdi unit is quite pricey though......easier to fit but the mod mentioned costs sweet f.a!!!!
william
Posted: Sat Jan 31, 2009 10:43 pm
by tanuki
true...but there are cheap HRC cdi's out there one went for £85 on the forum the other week and they do alot more than just remove the speed restriction
Posted: Tue Feb 03, 2009 3:05 am
by Honda_NC35
tanuki wrote:true...but there are cheap HRC cdi's out there one went for £85 on the forum the other week and they do alot more than just remove the speed restriction
That Cdi is mine now...
