Page 2 of 2
				Re: Double adjust forks and rear coil over damper
				Posted: Sat Jul 01, 2017 11:14 pm
				by moforockband
				It does fit the 73sp swingarm. IS this what you have or do you have the std swinger?
  I have the k6 fitted to mine. It is real close though, but does not rub once bolted up.
				Posted: Sun Jul 02, 2017 4:06 pm
				by wurlyvalve
				In the link that I pasted in, the swingarm on the right is what I have. With the "Takasago" sticker. It may be a GJ73a swingarm???? Well the right hand side doesn't quite touch, the left hand side the coil overhangs by about 5mm but - as luck would have it - there isn't a coil near the gusset. Not sure if that still holds true at full compression.....
It's bolted in!
				Posted: Sun Jul 02, 2017 8:28 pm
				by wurlyvalve
				It fits fine. I was being a nancy wuss. Rides well! 8mm static from just bolting it on.
