Re: Spacer to help after market fairing fit a bit nicer
Posted: Fri Mar 24, 2017 7:47 pm
by FluxCo
thanks dude, I am pretty chuff about it. Can you guys think of anything else I can make for the NC30?
I am thinking about some spacers for mounting different mirrors so I can see past my elbows.
Posted: Sat Mar 25, 2017 9:33 am
by Foxy400
Impressive. Can you make a an upper, headlight fairing for my NC35 please..and not in fluorescent green?
Posted: Sat Mar 25, 2017 7:13 pm
by FluxCo
I probably can, but it will be really messed up and not going to fit at all + I only have green filament at the moment. so, shall I go ahead?
on a separate note, I snapped one of the brackets in the rear center section of the fairing (just above the pillion seat) today. I am making a strut across the two screws to brace side panels together.
Will upload pics when done.
Posted: Sun Mar 26, 2017 5:12 pm
by FluxCo
Made a brace to hold the rear side panels together after snapping off one of the brackets
Posted: Sun Mar 26, 2017 5:17 pm
by richhemmings
Drawing up a model for printing the instrument foam clips is on my list after I broke one and had to cobble replacements together from other parts. These ate seemingly unavailable in Europe so could be a good one to make? I don't have the means to print them...
Sent from my P9000 using Tapatalk
Posted: Sun Mar 26, 2017 5:24 pm
by FluxCo
instrument foam clips? My NC30 has a microdash conversion, so I am not sure what the clip looks like. Can you send me a picture, I will do a mock up and print one for you.
If you send me the dimensions (in mm) I should be able to get some made up for you
Posted: Sun Mar 26, 2017 7:16 pm
by FluxCo
a quick video of how a spacer is printed
Posted: Sun Mar 26, 2017 7:26 pm
by Dynamohum
Good work how about replicating the nylon stem plug for the nc30 in white or the small cap for the rear wheel nut or bar end plugs for the nc35 in black ?
Posted: Sun Mar 26, 2017 7:29 pm
by FluxCo
which bit is the stem plug?
is the NC35 rear wheel nut hole + bar end holes the same size as my NC30?
