Re: Headlight Wiring (two in particular)
Posted: Mon Mar 06, 2017 11:29 am
I put a female bullet connector and boot on the wires in the headlight and that's all sorted.
Finally got round to tidying the starter relay mess up with a new plug and new relay.
Somebody had spliced into the harness to bypass the original starter relay and used what looked like a 14v generic job. Either way it was a total mess.
Before
After1
After2
If its of any interest, the replacement relay (like this below) comes with the connector the wrong way round (B & M dont match the original B & M fittings), you have to pop the cap off the top of the relay and use your original Honda one (the green cover) to make it compatible. Easy to do and saves you a few pennies, I've not read it anywhere else so figured I'd post.
CheapEbayStarterRelay
Before
After1
After2
