Brake calipers
Re: Brake calipers
that is something I don't know. I fitted the CBR6 brakes to my NC30 but this meant I had to change the braided lines as the caliper end banjo angle is different. I alos had to change m/c to a fireblade unit as the std NC30 m/c was just not working as well as it needed to. It was too soft and squidgy with enormous power. I needed some modulation.
If the NC35 m/c is the same then I would suggest getting a blade/sp1/cbr6rr one..but as they all use a similar type of later generation caliper you might be alright.
I would be asking someone with an RVF that has done the swap
RVF007
Re: Brake calipers
Post by RVF007 »
thanks for your time CMSMJ1, much appreciated ;)
so does anyone with an RVF know if this will work of will I have to change the lot?
fastdruid
Regular Member
Re: Brake calipers
Post by fastdruid »
Yep, NC30 M/C is the same as the NC35.
I swapped the track bike for a fireblade one (with CBR600RR calipers) and the brakes on that are *ace*.
Druid
Spike16
Re: Brake calipers
Post by Spike16 »
iv fitted a set of cbr600rr calipers m/s and braided lines today and am waiting to try them out 2moro im hoping they will be good, well compaired to my old completely stock setup they better be
on little question, as miney came already attached to lines with the fluid in i couldnt run the lines behind the throttle cables, and they currently rest on them, iv got some the rubber part to a p clip on the lines at that points so they shouldnt damage eachother, is this ok?
fastdruid
Regular Member
Re: Brake calipers
Post by fastdruid »
I'd personally sort it so that they sit correctly otherwise it may catch or fowl somewhere.
I'd take the throttle tube off and do it that way.
Druid
Re: Brake calipers
Have you not replace the fluid they came with? It'd be the wise thing to do, plus you can take the lines off then.
As druid said, take the time to get them routed properly, even if it does mean cracking the lines off.
Stopping is very important ^_^
So is not fowling steering :)
Plus, if you get it right from the offset you'll have less problems further on
Spike16
Re: Brake calipers
Post by Spike16 »
WOW!!! there crazy good!!! almost too good
yeh im going too but one of the screws holding the res on have rounded so im gona have to drill it out, il replace the fluid and route the lines correctly eventually when i have time
would recomend these brakes to everyone
Re: Brake calipers
Spike16 wrote:WOW!!! there crazy good!!! almost too good
have to agree. Even though the std braks on an NC30 are pretty hardcore...the uprated brakes are mental.
get yours bled and fettled Spike miladdo..will be even better.
btw - what pads you using?
Spike16
Re: Brake calipers
Post by Spike16 »
err the ones that came in them :) but il get some nissin oem ones when they need changing
one thing i have noticed but dont know if its right or not, when going slowly and applying the brakes you can almost hear them engaging, and smooth scraping type sound (although it may just be me)
and i had to space some of the bolts out that hold the adapters to the bike as they stuck out and were locking the disk (first time i tried to ride off in the garage i ended up doing a little burnout, pissed my dad off a treat ;) )
RVF007
Re: Brake calipers
Post by RVF007 »
sound like you have a winner there Spike16.
has anyone ever tried RS250 Brembo calipers?
