Rear brake hose
keithcar
Re: Rear brake hose
Im not sure if you can adjust theplacememnt of the brake lever on the nc30, at least i didnt see anything adjustable. I could be wrong. But the lever seems to be in the right place, my only gripe is the lever feels soft and mushy. There is no resistance, as if air was still in the lines. I spent a good hour bleeding them trying to get the lever to become more firm.declangaelic wrote:have you tried adjusting the rear brake lever?
i rode around for ages on the bike thinking you needed unreal flexibility in your leg to go up through the gears, then (about 5 months later) i adjusted the gear lever down (lengthened the linkage rod) and it was sooo much better.
pretty sure you can move the VFR rear brake lever, move it up so you have to go through less of a range of movement in the ankle and see how that feels
