NC24 - Wiring loom routing
- Bike owned: NC24 VFR 400 1988
Re: NC24 - Wiring loom routing
Oh dear. What's wrong with the carbs?
- Bike owned: VFR 400 NC24 CBX 550 F2
Hopefully nothing too bad, I've ordered new seals for all four as well as new needle valves. With a bit of luck it'll run fine after that, otherwise I'll probably be throwing lots of money that way soon... The previous owner sent them of to be ultrasonically cleaned, but the guy doing it probably used some detergent that was slightly too aggressive so the carbs came back with two needle valves so badly corroded that I've still not managed to get the needle out of the seat. There is also surface corrosion most everywhere (even on the main jet needles...).
I'll try to get som pictures up (or maybe even a project thread...)!
Could very well be worthwhile putting a project thread up and asking about the carbs on that in my opinion. If the seals and needles don't sort it then you're gonna need someone who knows what's what I should think! Really hope it doesn't end up costing you shitloads to sort out though!!
Project thread started, see: viewtopic.php?f=69&t=52250
Looks like a nice little project! Anything more I can take pictures of and such like just let me know.
- Bike owned: NC24 Rothmans
Hi, I'm new to NC24 as well and just before carbs job - cleaning and balancing. Can support with pics if some specific part needed.
Thanks for the support, I'll be sure to let you know if I need anything more!
Updated with some pictures of how it passes airbox etc. https://www.dropbox.com/sh/fm818n1ek1ba ... JhWMa?dl=0 hopefully that helps!
Thank you! I think that should be all I need to put my bike together (if only the new needle valves would arrive soon...).
