NC24 Rec/Reg modification question
- Bike owned: NC24, 250exc, 125 pittie
Re: NC24 Rec/Reg modification question
My battery seemed to be a goner but now I'm not sure, it was reading 11.8V and I discharged it to 10.5 as one does with a deep cycle. Charged it up to 13.8 on a trickle for a day and it hung up at 12.4 V after about 30 hours. I put it in the bike and cranked it with the stop engine button so it wouldn't start, so I could see what it dropped to and it hung at 11.5 under cranking for a good 5 seconds and when I let off it shot back up to 12.3V would you replace it or not? I'm not sure...
Thanks guys
Thanks guys
- Bike owned: RVF400 (NC35)
No-that sounds fine to me.
Thanks man, I was just worried that a crappy bat will ruin my new rec/reg.. how crappy would a bat need to be to do damage to the charging system?
A dead battery wouldn't recover to 12v after turning the engine over.
- speedy231278
12.4V isn't stellar, but it's far from disastrous. Are the figures given from a multimeter or your LED voltmeter? I only ask because I fitted one to my NC35 and it reads a little on the low side, but that might just be my wiring!
Mine reads 0.2 volt lower than my fluke which is a very accurate very expensive multimeter I got from my dad who got it as a gift from fluke themselves.
The readings were off the multimeter.. this morning the fluke was showing 12.3 and the voltmeter was showing 12.0
My battery reads about 12.8 when disconnected (i.e. ignition off) but around 12.2 when the ignition is on - I'm guessing that the lights cause this drain. When turning over it drops to around 11.5V - but then recovers happily, and charging voltage is 14.6V at the battery on mine.
You see that's much better than mine, when it's disconnected it reads 12.3 ish and if I leave it a few days it will drop 0.1 per day or so, my new rec/reg shows charging at about 13.8 at idle, what revs does yours charge 14.6 at? Maybe I should just get a new bat - they're not that expensive, at least then everything on the charging side will be good, I don't want to buy a rec too soon.. I'd rather buy petrol and ride ha.
Thanks for your help manic, really appreciate it bro!
I have an NC35 by the way...
But anyways - I was getting similar voltages to you before I did the reg/rec wiring mod
viewtopic.php?f=24&t=49877
Essentially I was losing 1v ish in the wiring loom before I did the mod.
Was very simple to do.
