3TJ Forks. Soft and soggy!
				topfridgeman
- Bike owned: 1 or 2
Re: 3TJ Forks. Soft and soggy!
Have you tried cartridge emulators?
				chrisexup
- Bike owned: fzr6003tj kr1-s d675 ypvs350
i have used YSS cartridge emulators, not sure wether i tried them in the 3tj though (i've been through so many iterations of front ends i can't remember what's in all these forks i've got   )
i remember that the adjusters didn't have as big an effect on the damping as i wanted. Just putting thicker oil and decreasing the air gap in a set of ThunderAce forks was a good improvement, so once i'm happy with the spring weight i tend to just mess with fork oil height/weight. The damper rods need extra/bigger holes drilling when fitting cartridge emulators, if i tried them again i would start off with fewer/smaller holes than YSS recommend, to see what effect that has.
 ) i remember that the adjusters didn't have as big an effect on the damping as i wanted. Just putting thicker oil and decreasing the air gap in a set of ThunderAce forks was a good improvement, so once i'm happy with the spring weight i tend to just mess with fork oil height/weight. The damper rods need extra/bigger holes drilling when fitting cartridge emulators, if i tried them again i would start off with fewer/smaller holes than YSS recommend, to see what effect that has.
