New suspension
				richyrd5
Re: New suspension
i have a rr5 shock for sale if your thinking of going for it!
				Keysie
Re: New suspension
What would I need to do to it to make it fit the NC30?
				richyrd5
Re: New suspension
sorry its gone now!
				watafu
Re: New suspension
The shock itself should be fine to go in as is depending on your weight, 10+ stone and you'll probably have to upgrade the spring. The frame needs a little ground off a mount which will take you 5-10mins with a file if that, and its instructions are in the s1000rr. The biggest problem is moving the ignition coil, I did it wrong, so take your time working this one out if your ever planning on doing this mod
				richyrd5
Re: New suspension
where did you move the coil to after watafu?
				watafu
Re: New suspension
I moved it up into the cavity in front of the regulator and bolted it to a bit of metal mounted between the two subframe spars
				richyrd5
Re: New suspension
ah righty,thanks
