Loosing all power on front brakes on NC30
manicguitarist
Bike owned: RVF400 (NC35)
Re: Loosing all power on front brakes on NC30
Post by manicguitarist »
Wemoto
Mbrandt
Post by Mbrandt »
Thank you.
Mbrandt wrote:Ok, I'll try that then. Any suggestions on where to buy an oem repair kit?
not just that but check the serivce book in the document library, it gives the services limits for the master cylinder.
not comon but not super rare to find a master-cylinder that is too worn.
Most likely just a bad seal kit been installed or some very hard to release trapped air.
After re-bleeding it I always get somebody to hold the lever in and with a rag over the banjo bolt on the mc gently crack it open until you start to loose pressure and tighten it back up before lever hits the bars, this will stop air getting in but purges any trapped air you get in the master / banjo part which can be pain in the arse to get out sometimes.
Mbrandt
Post by Mbrandt »
Thank you for the tip, Neosophist. When I get to buying a kit and fixing it, I will write here with the results.
I never run out of uses for my money, funny that. Too bad i regularly run out of money.
Mbrandt
Post by Mbrandt »
I fixed the front brake, at least they've been working for a couple of months now. It was the seal kit, but I bought a whole used assembly, because that was cheaper then just buying the good seal kit..! I will buy the seal kit when I have money to spare.
Thanks for all the help guys.
