Disc off set?
Re: Disc off set?
Thanks KaylaKayla850 wrote:What about an FZR1000 EXUP/RU front wheel? They have a slightly wider hub so you might not need quite so much disc offset?
It's for my XV 750 cafe racer, I'm using wire spokes wheels with twin discs, the standard brake is scary!
Re: Disc off set?
is that something like a Talon wheel ?
You might find it easier to get a different hub made up, or see if there's something stock from a spoked wheel manufacturer
Re: Disc off set?
It's a standard Yamaha wheel from either an RD 400 or more likely a XS 7/850. It's a really nice hub that took ages to find as most are only single disc fitment.
The old disc has about 12mm offset already so I need about 13mm more between the wheel and caliper spacers,
The old discs weight 3kg each! The FZR ones are 1.5kg each but only have about 7mm offset, old ones look more "old skool" and better for it so I will probably go with them.
All this ^ and I'm still learning how to work the lathe!
Anybody what to buy some swarf? "We got both types country and western"
(alloy and steel)
Free bag of popcorn to first person that know what film the above quote comes from........
(alloy and steel)
Re: Disc off set?
Have you looked at OW01 discs, they had an offset ... maybe EBC do a set to suit cheaper than original
Re: Disc off set?
They have have a veyy big offset but they are 320mm so won't fit,
Mine need to be 298mm.
I'll get my ass down the garage tomorrow and have a proper measure up then decide what way to go.
Re: Disc off set?
So why not take them to a Machine Shop, and have them taken down to 298mm?
Re: Disc off set?
Because there will be a very jagged edge if I try to take 22mm off the diameter of a disc with holes in it!Wraith wrote:So why not take them to a Machine Shop, and have them taken down to 298mm?
- Variablevalves suck
Re: Disc off set?
So is it not possible to move the calipers with new mounts?
If you get really stuck you could talk to EBC, not sure if they still offer the custom service but they made me one offs and the price was not much more than the stock replacement price,
Basically had a 298mm yzf disc fitted to gsxr carrier by them.
Re: Disc off set?
Sounds like custom discs is the way to go
- Kayla850
- Bike owned: Sunn Tzar S2
Re: Disc off set?
If you spaced the calipers in would they foul the spokes?
www.projection-racing.com
www.pjcfasteners.com
