Is it possible to convert earlier N29 Forks to later type?
marty400
Re: Is it possible to convert earlier N29 Forks to later typ
Post by marty400 »
Found this, via google search:
(Man, search function on this forum is a bit naff!)
viewtopic.php?f=26&t=44834
Food for thought!
How does the ride of a "rvf" versus "cbr6" conversion compare?!
JZH
Bike owned: RSCBRRVFVFRST
Post by JZH »
marty400 wrote: ...and thinking about it, what about the compression dampener at the bottom of the CBR600 forks though?
If you want compression adjustment, you will probably have to fit F4i type forks, or maybe early 600RR forks. I think they're shorter than F4i forks--but you'd need to fit the whole front end, not just the forks.
I don't see how you could add a compression adjuster to lowers that never had it--absent a lot of welding and machining.
Ciao,
JZH
London, UK/So.Cal., USA
www.vsource.org
tanuki
Post by tanuki »
richyrd5 wrote:If the cbr yokes are smaller then to accept the vfr forks(complete)then ream out yokes.not difficult!
they are the same size....
