nc 30 getting warmer than expected
shango
Re: nc 30 getting warmer than expected
Post by shango »
Hey guys,
Quick question. Brake cables were not tied up and wore through my radiator on my RVF. Anyone know if the NC30 Radiator will fit a NC35? Thanks.
top or bottom?
Both should fit - the 35 top rad is wider than the 30 top but as you are fitting 30 to 35..you are sorted
bottom are the same afaik
fastdruid
Regular Member
Post by fastdruid »
AFAIR the main difference is the tabs on the top, the NC35 are flat to the radiator top, the ones on the NC30 are at 90 degrees (ie sticking up).
ISTR looking at the rads thinking bending over the tabs should see the NC30 rad fit the 35 but I didn't actually try it.
Oh yeah and the bottom rads are identical.
Druid
shango
Post by shango »
thanks lads. Ill give it a shot sure and let ya know!
