Triplespeed
- Bike owned: Nc30, CBR600
Post
by Triplespeed » Fri Jul 11, 2014 2:10 pm
Neosophist wrote:sounds your like pilot circuit / jets are blocked, your pilot screws / idle speed isnt set right and / or your float heights are off.
maybe a combination ofall of them
I think your right mate , my first attempt must not have been up to scratch as I dont have a decent airline (and now its been robbed from work)
I'll give them a proper stripdown and see if i can sort it out
Post
by Drunkn Munky » Fri Jul 11, 2014 2:27 pm
Bring the carbs with you when you collect the plugs mate and were get the compressor on them
Triplespeed
Post
by Triplespeed » Fri Jul 11, 2014 9:46 pm
Drunkn Munky wrote:Bring the carbs with you when you collect the plugs mate and were get the compressor on them
Cheers mate will do. I'm on night shift at the moment but I'll give you a shout next week
watafu
Post
by watafu » Fri Jul 11, 2014 10:27 pm
One thing you could try as I was in the same situation is taking your plugs out and giving them a sand with some 1200grit paper. Then bump start the bike, nothing else worked when I did it, now its running great, might work for you, might not.
Triplespeed
Post
by Triplespeed » Sat Jul 12, 2014 2:03 pm
watafu wrote:One thing you could try as I was in the same situation is taking your plugs out and giving them a sand with some 1200grit paper. Then bump start the bike, nothing else worked when I did it, now its running great, might work for you, might not.
Sorry for the rookie question but why bump start it and not non the button? The plugs are not in the best condition so I'll try some from DM
watafu
Post
by watafu » Sun Jul 13, 2014 10:46 pm
Rules out the chance your battery is causing he issue. Tbh I'm not sure why it works but have had a similar situation on 3 different types of bikes, they would not run on the button, jump starting at the battery and even the starter motor. Soon. As I bump started them they fired right up and ran without issue. Weird but give it a shot, second gear worked a treat for me at a mild jog
arsey30
- Bike owned: ftr223 650 bros
Post
by arsey30 » Mon Jul 14, 2014 8:19 am
Depending on engine and starter spec, the starter motor will draw perhaps 50A or more, so reducing the battery voltage. [to around 10v?]
Bump starting allows full battery voltage to coils.
watafu
Post
by watafu » Mon Jul 14, 2014 5:07 pm
Ah right, always wondered how it worked
Triplespeed
Post
by Triplespeed » Mon Jul 14, 2014 6:39 pm
watafu wrote:Ah right, always wondered how it worked
I'm learning loads with these faults so all good
Triplespeed
Post
by Triplespeed » Wed Jul 16, 2014 2:31 pm
Just as an update the bikes had new plugs and the jets confirmed to be clear, still the problem there . Head against wall and strike repeatedly , will try the bump start method and after that I'm done I think
