Rusted tank
Triplespeed
Bike owned: Nc30, CBR600
Re: Rusted tank
Post by Triplespeed »
micpec wrote:Tried it myself first time on a moped restoration (my very first moped nut and bolt project) back in 1993. I could not get few parts of the frame and engine off...mind you the moped was a 1969 Puch MV50 3-gear speed that never ever was taken apart. A bath in plenthy coke for at least one day and rinse it properly did the jobs perfect! I trust this method and coke is cheap. :grin:
I know those old puch mopeds can rust like a novas arches so I can guess the extent.
If it worked for you then I'll give it a go and leave it for a day then see if it's cured - if all else fails I'll have something to add rum to
AdrenalineJunky
Bike owned: VFR400 NC30
Re: Rusted tank
Post by AdrenalineJunky »
You can actually reverse the chemical reaction that causes rust, to remove it all. Takes 1 to 2 days, you need:
a battery charger + battery (or other 12V DC supply)
some jump leads
some soda crystals
a piece of iron or mild steel
Instructions as per an old issue of Practical Sportsbikes:
It works!
Triplespeed
Re: Rusted tank
AdrenalineJunky wrote:You can actually reverse the chemical reaction that causes rust, to remove it all. Takes 1 to 2 days, you need:
some jump leads
some soda crystals
It works!
I had read about electrolysis method and heard good things about it. If the coke method fails and i have to re- line the tank ill use this prior to chemical methods.
Thank you for posting up - its nice to know folks have been through this before .
When I have started the tank ill post up . That reminds me I need to update my project thread...
jack1991
Re: Rusted tank
Post by jack1991 »
My tank on my vfr 400 nc24 was quite rusty and blocking the carbs making it run rough I have just used the por 15 method and it was brilliant it started coming out a very rusty brown colour after the first stage it came out crystal clear here is a link
http://www.frost.co.uk/por15-motorcycle ... r-kit.html
DocV400
Bike owned: 1200 Bandit ~ NC30 ~ Italjet
Rusted tank
Post by DocV400 »
Much better use for it than drinking the evil c**p anyway :down:
A Pessimist is just an Optimist, with experience.
Doc out . . .
Triplespeed
Re: Rusted tank
Thank you for the link Jack, the POR will be the last chance saloon but I`ll be chucking a load of smartprice coke in there tomorrow and seeing how it goes. If it makes your teeth feel like theyre curling up tit should strip away the rust :)
