FZR 400 GENESIS CDI FAULTY ???
willandrip
kawasakiinit
willandrip
Re: FZR 400 GENESIS CDI FAULTY ???
I was already working on a quip for your description of the last photo before I scrolled down to it.
You beat me to it;that pic needs no retort.
kawasakiinit
check this will its got me chuckling bless him http://www.youtube.com/watch?v=frv7TwQgY7I
willandrip
Saw it on another forum previously; some thought it a set up but judging by some posts on forums, seems totally legit to me.
Usually teens would have tried to thrash it away in a tantrum so that young un must be a bit timid though !
Take the airbox off run the engine and spray some carb cleaner over the carb intake. If it picks up then its fuel.
kawasakiinit
tried that first with easy start no change? thanks for suggestion tho . how evil can a chicken be ?????? lol
dobbslc
Have you tried swapping carb bodies?
I sounds like a problem I had on my 3TJ once. I was the tiny drilling in the carb body that were blocked.
Ultrasonic cleaner?
Ultrasonic cleaner?
kawasakiinit
Not tried swapping bodies over as I didnt want to undo all the butter fly linkage etc but could be worth a shout.
So. Fuel, Compression, Ignition.
If the easy start didn't work then I don't think swapping the carb bodies will do much, and if the easystart doesn't ignite then it would point to electrics or compression.
You swapped the coils, I take it the 2/3 coil ran 1/4 without any problems, but No.2 still didn't run with the 1/4 coil ?You seem to have done all the things usually done ... have you compression tested it ?
