NC30 Shock Options
- superlite
 - Bike owned: TLS, LB80 x 2
Re: NC30 Shock Options
I can back him up on that one - it is extremely good!Stickshift wrote:My race bike has a reworked standard shock to suit the rules. It rocks.
We're restricted to standard shocks for racing in Aus, but I've never felt any need to spend big bucks on an aftermarket when a re-worked standard shock is MUCH more than adequate.
'Take it to the Back'
As above, any suspension expert could point you in the right direction. Spring weights that work well are widely known, just this and a revalve and freshen will make a huge difference. Cost is subjective, but at a guess it could only be half as much as a cheaper aftermarket option.katana wrote:What did you have done and ideas of cost please.Stickshift wrote:New spring, compression adjustment added to remote res, and revalved. Any decent shock place will be able to mod the standard unit. It rocks.
Find a good suspension guru from someone that races the same sort of bike.
				RVFJE
Stickshift - who are using in Oz?Stickshift wrote:As above, any suspension expert could point you in the right direction. Spring weights that work well are widely known, just this and a revalve and freshen will make a huge difference. Cost is subjective, but at a guess it could only be half as much as a cheaper aftermarket option.katana wrote:What did you have done and ideas of cost please.Stickshift wrote:New spring, compression adjustment added to remote res, and revalved. Any decent shock place will be able to mod the standard unit. It rocks.
- superlite
I'm pretty sure he had his done by the Honda guru Trevor Manley, but I'm sure he can tell you more.RVFJE wrote:Stickshift - who are using in Oz?
