Page 2 of 3
				Re: help
				Posted: Tue Dec 31, 2013 11:49 am
				by freemo
				thankyou i am going to take it off today and have a look inside ,i will let you know the outcome ,mark.
				Re: help
				Posted: Tue Dec 31, 2013 5:07 pm
				by freemo
				hi evil took casing of this aft bearing still in situ,i can see how shaft for starter motor fits in it,and have relocated it into engine,,the other cog to the right of it came off when i took the casing off ,along with said shaft,it dosen,t appear to have anything holding it on, unless it stays put when casing goes back on ,is it free floating so to speak? ,i also got both dowels out without breaking them so thankyou for your patience with me and your help always very much appreciated,regards mark.
				Re: help
				Posted: Tue Dec 31, 2013 5:28 pm
				by willandrip
The intermediate gears (2 and 3 ) locate on shafts (4) that fit into the crankcase and the starter cover.
The bearing (10) is identical on all models.
Do not force the cover on at refit. sometimes it takes a little jiggling of gears and case.
It is not unknown for the starter shaft (1) to be forced into the motor damaging it.
Ensure the bearing is seated fully home in the new casing or the casing wont seal and gears will bind.
If it has suffered damage sever enough to totally destroy the casing;ensure no debris has invaded the crankcases.
Tales are legion of racers who remove engine sump plate to check this after high speed spills force gravel into the crank.
				Re: help
				Posted: Tue Dec 31, 2013 8:00 pm
				by freemo
				that diagram is brilliant,number 2 gear is the loose fit one on mine it just seems to sit on shaft and looking at diagram there dosen,t seem to be anything holding it on which is how mine is so that all looks good thankyou once again and a happy new year to you regards mark.
				Re: help
				Posted: Tue Dec 31, 2013 8:17 pm
				by Evilchicken0
				Youre looking from the engine in that diagram, the casing supports the dowels and houses the bearing.
				Re: help
				Posted: Tue Dec 31, 2013 9:47 pm
				by hunter
				willandrip wrote:Yep;same part.
Get a new gasket too.
Be aware the locating dowels are made from tinfoil.
 if swapping them over.
A little tip on removing these dowels,
Find yourself a bolt or better still a drill bit that fits nicely inside the dowel,Then grip the dowel with a molegrips,
Twist and pull,Out comes the dowel without being crushed..
				Re: help
				Posted: Wed Jan 01, 2014 12:24 am
				by rockTJ
				I am pretty sure I have an intact, with bearing, starter cover in my shed.  Will look tomorow.  I know it will be black and slightly scabby but it is a 3TJ item, not a 600 one.  PM me your address.
It's a leftover from my build.
Chris
				Re: help
				Posted: Wed Jan 01, 2014 4:14 pm
				by freemo
				thanks to all of you, your,e brilliant,have a great 2014 regards mark.
				Re: help
				Posted: Wed Jan 01, 2014 5:59 pm
				by Evilchicken0
				If you want it to be silver, mask off the bearing, use some paint stripper and then spray it with 5 Wheels Silver.
				Re: help
				Posted: Thu Jan 02, 2014 9:57 pm
				by freemo
				good advice evil will do as suggested regards mark.
