3en2 5eb front end swap.
- Kayla850
- Bike owned: Sunn Tzar S2
Re: 3en2 5eb front end swap.
Hi Chris,rockTJ wrote:I was hoping to not have to do the machining bit with the YZF wheel, thanks for the heads up. I already have a Thunderace wheel here so will just go ahead with that then - the same work is needed but the discs from the R1 wheel will fit.Kayla850 wrote: You can use a YZF750 wheel in 4XV forks but you need to machine 8mm off the inside of the left fork bottom to fit the speedo drive in.
Kayla how much would you charge to do the milling work required? I would source an R1 lower stanchion and send it up.
Chris
We could do it for £20 plus return post, or call in and DIY
 It's a 5 minute job but it takes a good while to get everything set up and straight/square/parallel.
 It's a 5 minute job but it takes a good while to get everything set up and straight/square/parallel.Useful project bike parts and stuff and things-
www.projection-racing.com
www.pjcfasteners.com
