Page 2 of 2
Re: How far up the scale before fan comes on?
Posted: Thu Oct 23, 2008 7:46 pm
by fastdruid
NC35! wrote:Basically, I need to check for continuity between battery neg and, for example, the bolthead which holds the radiator and fan together?
I'd do it to the body of the fan switch myself.
Druid
Posted: Thu Oct 23, 2008 8:38 pm
by NC35!
fastdruid wrote:NC35! wrote:Basically, I need to check for continuity between battery neg and, for example, the bolthead which holds the radiator and fan together?
Druid
You're the man! After I went back out, I checked for continuity between the fan and earth to find nothing, then tried again from the flats of the switch to earth to still find nothing.
I took the lower rad off and cleaned up the connections between the earthing wire and the fan/radiator mount, then checked again to find perfect continuity. I let the engine warm up again, and just after half-way up the scale, the fan came on!
Fantastic! Thanks for stopping me taking the switch out to do the Haynes check-the-switch-with-boiling-coolant-on-the-cooker-while-the-boss-is-in-and-no-doubt-ranting-at-me routine!
I'm very happy! Thanks! :)
Posted: Thu Oct 23, 2008 8:51 pm
PS - Agree, nice road :D
Glad you got it sorted!!
I posted that in the wrong thread.. had like 10 open :D
Posted: Thu Oct 23, 2008 9:40 pm
by fastdruid
NC35! wrote:You're the man! After I went back out, I checked for continuity between the fan and earth to find nothing, then tried again from the flats of the switch to earth to still find nothing.
Hurrah!! :D
I've found I always seem to look for the complicated reason yet so often it's something small and stupid.
So now I try and start on the obvious and easy to check and work up.
Druid
Posted: Thu Oct 23, 2008 9:45 pm
fastdruid wrote:NC35! wrote:You're the man! After I went back out, I checked for continuity between the fan and earth to find nothing, then tried again from the flats of the switch to earth to still find nothing.
Hurrah!! :D
Druid
lmao.. i know that feeling, can't believe I forgot about the earth tbh! :D
