VFr 400 nc30 Backfiring :(
Re: VFr 400 nc30 Backfiring :(
Cam timing then... Backfiring etc is a typical sign, especially if after being rebuilt.
it is practically impossible to get the bike to run if the timing is out - you'll be risking valves<>piston interface.
plugs not even dirty - as in wet? So, you have no fuel to them??
yes.. cam timing is super easy with it beign gear cams.CMSMJ1 wrote:it is practically impossible to get the bike to run if the timing is out - you'll be risking valves<>piston interface.
do you ahve the right cams in the right places? front cams in the front, rear cams in the rear?
Hi all, sorry was away for a while. what i mean by the plugs is that it doesnt even look like its been fired on , they looked like they have just been put in , I will try and sort out the cam timing ,but i find it hard as i can find no one who know's these bikes cam timing
if the plugs are not getting wet then you are not getting fuel.
The cam timing is easy - it has geared cams and so you cannot get it out and if you do it does not work at all, let alone make attempts to start.
My money is on a lack of fuel to the cylinders - how else would you expect them to be dry?
the service manual is in the downloads section, it has a step by step guide on how to set the cam timing. unless you took the cams out and it ran at somepoint befoe then there is 99% certain not camtiming, it doesnt go outParagon wrote:Hi all, sorry was away for a while. what i mean by the plugs is that it doesnt even look like its been fired on , they looked like they have just been put in , I will try and sort out the cam timing ,but i find it hard as i can find no one who know's these bikes cam timing
