clutch questions
Re: clutch questions
thats knackered.krisztian_andre wrote:The oil consumption is 1 ml/km at highway speeds and there is a lot of carbon fouling on the top of the pistons. I'll know more this week after the compression and leakdown tests. Should I do them on a hot or cold a engine?
Every one ive owned has never used any noticable amount of oil between changes (3000km)
Sounds like worn bores / rings which is why your burning oil off.
Whats it look like shining a toruche down the inlets, can you see any oil leaking around the valve stem seals?
Sounds unliley its using that much oil from stem seals though
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
There is brown oil sludge on every intake valve and the oil consumption is 1/10th if I just drive around low speed in the city. That doesn't mean the barrels and/or rings aren't bad too.
Neosophist wrote:thats knackered.krisztian_andre wrote:The oil consumption is 1 ml/km at highway speeds and there is a lot of carbon fouling on the top of the pistons. I'll know more this week after the compression and leakdown tests. Should I do them on a hot or cold a engine?
The brown sludge is likely to be blowback from the oil being pumped into the bores, oil will be fresher looking, again hardeer to explain.krisztian_andre wrote:There is brown oil sludge on every intake valve and the oil consumption is 1/10th if I just drive around low speed in the city. That doesn't mean the barrels and/or rings aren't bad too.
Do a compression test anyway as you said you have the equipment coming.
After the test crack the plugs out adn pour a teaspoon of oil down the plug hole and do another test of each cylinder.
if the compression goes up you have worn rings / bores.
plenty of engines around in Japan, since your close cant you get one shipped over?
krisztian_andre
Here's the dyno plot. The shop tried to charge me for the A/F plot as a separate run again saying it's a separate chart, why not charge for the torque or the humidity or the temperature separately hehe.
Standard except the full tyga system and 112/115 jets:
It made so much smoke above 10000rpm that the dyno room's ventilation couldn't cope with it. Eventually I'll import an engine from Japan, total cost should be around 500-600 GBP.
Aye, that motor is buggered. I can imagine it is running so rich due to the oil in the system - it is burning it so counts as fuel.
A shame but they all have to die sometime!.
Would not worry about your clutch or even spend anything on this - it is a case of throwing good money after bad.
krisztian_andre
Rest in pieces little engine.
