Gears - bike or me ?
Re: Gears - bike or me ?
Who the fuck cruises in first gear?
These bikes are made to be raced they scream MORE, in a sick sadistic way, HURT ME MORE, Hondas have always had shitty 1/2gears and neutral being a bitch to find, stop being a girl and ride it harder.
Hope that helps
Rick
Hope that helps
Rick
- benny
30mph zone, or accelerate to 40 without changing up then realise ill be at 40 for a while so should pop it in 2nd.porndoguk wrote:Who the fuck cruises in first gear?
Hope that helps
Rick
I push it when I'm in Matlock etc. not Nottingham centre :')
Thanks for the advice
DM104 for the road race team.
Did you get the mirror mate?benny wrote:30mph zone, or accelerate to 40 without changing up then realise ill be at 40 for a while so should pop it in 2nd.porndoguk wrote:Who the fuck cruises in first gear?
Hope that helps
Rick
- benny
I did thanks, I think I'm going to find a tool to tighten my old one as that bung you sent should fit the hole in my old one, because that one you sent is a bit more faded so looks odd and has the bung on top so stands out a bit.
Yeah i went through a period of loose mirrors so i drilled through and changed the nut for a nyloc one, hence why i sent a spare bung to make them match and let you stick a nyloc on the other side, i guess you could put some black vinyl on over it.benny wrote:I did thanks, I think I'm going to find a tool to tighten my old one as that bung you sent should fit the hole in my old one, because that one you sent is a bit more faded so looks odd and has the bung on top so stands out a bit.
FYI the hole for that grommet is a 20mm diameter
Rick
- benny
Someone has already done that to my left mirror (don't know if they changed the nut) but did it on the bottom so you can't see it. What did you use to hold and tighten the nut? AT the moment I put my finger on it and try to spin the mirror leg (with it off the bike) which doesn't produce brilliant results hence looking for new mirror!porndoguk wrote:Yeah i went through a period of loose mirrors so i drilled through and changed the nut for a nyloc one, hence why i sent a spare bung to make them match and let you stick a nyloc on the other side, i guess you could put some black vinyl on over it.benny wrote:I did thanks, I think I'm going to find a tool to tighten my old one as that bung you sent should fit the hole in my old one, because that one you sent is a bit more faded so looks odd and has the bung on top so stands out a bit.
Rick
10mm spanner, its an m6 thread/nyloc nut
- bikemonkey
Hope that helps
Rick
Cruising at 30mph in first?
High fuel consumption then....
It'll easily cruise in 3rd at 30mph, 4th at 40 and so on.
- benny
That's why I'm changing up to second
it's normally just between traffic lights so maybe I shouldnt call it cruising
- bikemonkey
I was about to say!
I always change before 7Krpm round town if possible, keeps it smooth
