Page 2 of 3
Re: Single front disk
Posted: Fri Oct 17, 2008 8:44 am
by royster81
nne,if the police are about just make sure they are on the side with the disc...
Posted: Fri Oct 17, 2008 8:53 am
by Smev
Or just buy my discs off me and the problem is solved!!!
Posted: Fri Oct 17, 2008 9:25 am
by Simon_Ed
i wouldn't risk running one disc, maybe on a 125 where its supposed to have one. If it was supposed to run with one surely honda would have left one off??
Buy a set of 2nd hand ones or save up for some pattern ones.If you can't afford to run safely you shouldn't be riding sorry
Si
Posted: Fri Oct 17, 2008 10:40 am
by hannakournikova
i can see it not being used a short term fix, never actually getting fixed and running like that for a long time ;)
Posted: Fri Oct 17, 2008 11:37 am
by superlite
Simon_Ed wrote:i wouldn't risk running one disc, maybe on a 125 where its supposed to have one. If it was supposed to run with one surely honda would have left one off??
Honda CBR250s (amongst other Honda models) had two different braking configs: The single disc MC19 and the twin disc MC22. Sure, they're designed to run their seperate configs, but they each brake alright with the same (similar) gear.
As it's only a stop gap measure, It will be fine. Just as space saving tyres are fine - as a stop gap measure ;)
Posted: Fri Oct 17, 2008 11:57 am
by viper_biker
Here's an idea, what about not fitting any brakes and just using your feet to stop you, it worked fine for the Ant Hill Mob,
Posted: Fri Oct 17, 2008 1:26 pm
by fastdruid
Actually the MC14 and MC17 had twin discs then it moved to a single only for the the MC19 before it went back to twin for the MC22.
Personally I wouldn't do it but at the same time I wouldn't worry about it if I had to in an emergency.
Druid
Posted: Fri Oct 17, 2008 1:32 pm
by superlite
fastdruid wrote:Actually the MC14 and MC17 had twin discs then it moved to a single only for the the MC19 before it went back to twin for the MC22. Druid
I realise that there are other CBR250 models. I'm not familiar with them though as they're not imported into AUS because they're not "cool enough" for learners.
Interestingly, the RVF400 is the "coolest" learner ride down under at the moment. NC30s aint legal because of the power to weight rule - crazy huh!
Posted: Fri Oct 17, 2008 1:39 pm
by fastdruid
I'm cheating by having an MC17...
One day I'll fix it too...
Druid
Posted: Fri Oct 17, 2008 7:13 pm
by Morespeedvicar
Hiya,
it should be fine as long as you dont do any track riding. loads a bikes only use one disc, an as its only a temp measure it should be ok. Just remember your stopping distance maybe a bit longer, or just squeze twice as hard as usuall!!!!!
Ian
