Gas milage on the NC30
- speedy231278
Re: Gas milage on the NC30
I like to keep an eye on the mileage purely as I believe that if it suddenly changes dramatically it might be an indication that something is not right somewhere. Like when I started to run onto reserve 20kms earlier than normal on a regular basis and discovered the fuel tap to carbs hose had a nasty kink in it, which also caused a slight issue with fuel starvation after running onto reserve.
- Bike owned: GPX 250, NC30
I got 164km on my last tank. That is the lowest ever. Just started a new job and have been commuting 8km everyday .
My usual range is 180-200. Cruising at 100kph for an entire tank got me about 280km.
- Location: Oxford, Peterborough, new territories Hong Kong
I have managed to get 190km's with about 5litres left in the tank and that wasn't conserved riding.
Kennon
Kennon
- Bike owned: VFR400, CBR600RR
Just switched to reserve on the way to work tonight at 145km...yikes seems very low to me, mostly city driving short trips but still I think I should look into this ??? I just bought the bike so I have no idea what to expect. I will fill up tank again and see what it takes to top it up and edit this post...
OK so I filled up today and it took 12.1 litres after riding just 158km, city mostly, still seems very low to me. By my calculations that's only 37.6 mpg ??? I thought it would get at least 40mpg even in city ?
your going to consume allot in the city only gets better on the open road in clean air and a higher cog
Kennon
Kennon
I hope your right Kennon ! I am going on a 100km hwy ride next weekend,weather permitting, so I will see how it does then... :)
Don
Don
Yikes, I only average 150 by myself, but I ride hard. Yesterday took a half highway/half city trip with my girl on the back. I reached the reserve at 160km trying to take it a "little" easy. Nothing over 160kph, don't want to scare the missus.
- speedy231278
193 again last weekend for me. To be honest, I'm very pleased. I have no idea what I've done to the bike to make any difference (carbs not been tinkered with for several years, and never by me - yet) and no parts have been changed other than normal stuff like plugs, oil and coolant) yet I'm normally getting 10-20k more than I've been getting for years. I used to get 190 or so when I first got the bike, but after a few years it dropped to 170-180 at best. Maybe it's because I spend ages squeezing the last drop in the tank.....
- Bike owned: MG v35 II, NC30, MG NF Mil.
6 l/100km on 130km/h highway 112/115 jetting, tyga system, 35 Celsius, high humidity, sea level
+ 1l of oil/1000km
- speedy231278
You what? It drinks a litre of oil in a bit over 600 miles??? Does it think it's two-stroke? I've done 80000kms on my NC35 and I've never found it to get anywhere close to the lower mark on the dipstick. I don't recall ever actually topping the oil up between changes. Mine would be in bits trying to find the leak or dodgy valve stem seal!
