CONFUKULATED REGARDING DERESTRICTING
Morespeedvicar
Re: CONFUKULATED REGARDING DERESTRICTING
Post by Morespeedvicar »
125mph isnt bad in anybodies book, depends on how big you are, wind and god knows wat else, its fast enough so dont worry about it!
Just try and do the resistor mod like drunky monkey says, i dont think you even need the resistor, i sure somebody on here just straps whatever wire the sensor sire is straight to the 12v at the cdi end.
Hope your testing this on a track!!!??? lol
Ian
Jac-al
Post by Jac-al »
no tracks where i live only the power hiway behind the JHB int airport. illegal drags on sundays, beleive it or not- organised by a couple metro cops, SA ROCKS!!
200ks is 125 mph innit? That is plenty for a 400.
Jac-al
Post by Jac-al »
the fact that i got 182 in 4th i expected to get more that 202 in 6th. only an extra 20km/h in the 2 top gears doesnt sound right
Morespeedvicar
without sticking it on a dyno your never gonna know how good your fueling is or how much power your getting. Dont think i've had any more than that out of either of my 400's and i only weigh 9 stone with me leathers on! Remember there 20 year old bike now and the engines are prob getting abit past there best.
If your sure theres more to come, then maybe go up a jet size and put in a new airfilter, and a proper full service, but i'd just be happy with wat your getting, these little bikes are about getting round corners if you want more top end get a bigger bike.
Ian
Jac-al
Post by Jac-al »
its been on a dyno, check cammos jettin thread
What gearing is it running?
At the end of the day 60 ish HP is never going to go much faster than 130mph at the most..
Jac-al
Post by Jac-al »
must be standard jap spec. all i i know is the chain is a 525
you'll have stamped on the sproclets the numbers of teeth - front is 15T standard and the rear is 40T Should be easy to see the rear one at least as that is also the one that is changed easily.
Jac-al
Post by Jac-al »
40t on the rear. why, what difference will goin bigger/smaller make.
