Page 2 of 2
				Re: help with gk76a timing
				Posted: Fri Mar 01, 2013 8:11 am
				by Variablevalves suck
				I would be checking the spark first, sounds electrical.
				Posted: Fri Mar 01, 2013 11:56 am
				by sa 71
				So I've checked I have a good strong spark on all 4 cylinders
! But how can I check the spark is in the right cylinder at the right time?
				Posted: Fri Mar 01, 2013 8:10 pm
				You can not check it.
Makesure the low tension wires are on the correct coil as it sounds like the sort of problem you get when back to front.
				Posted: Sat Mar 02, 2013 9:39 am
				by sa 71
				Another quick question on the chi unit which of the coil wires are on top? Is it the white one or the black/yellow one?
				Posted: Tue Mar 05, 2013 7:49 pm
				by sa 71
				It's alive :) thanks for all the help guys...
				Posted: Tue Mar 05, 2013 10:11 pm
				Great news.
What did you do to fix it?
				Posted: Wed Mar 06, 2013 8:49 pm
				by sa 71
				're-checked the timing.  Which was out but 1 tooth.  Then  checked for signal from the cdi to the  coils. I found one of them was shorting out so it was always firing.... run a new set of wires for the  coils.... and it started..... spent the rest of today rebuilding her and noticed the rev counter wasn't working . So double check the wiring diagram, and the coil wires extend to the rev counter. So I run fresh wires there to.... all fixed now just need to seal the tank an then fill it up....:) just in time fir summer..
				Posted: Wed Mar 06, 2013 9:11 pm
				by donk
				Well done mate glad you got it going I wish i was going to be on the road for summer
				Posted: Wed Nov 25, 2020 5:03 pm
				by Colacharlie
				I’ve got a non runner GK76 and just wondering how I tell which is the right and left side of the coil and? Two ht leads go to one single coil and the other two HT leads go to the same coil but those have both have click on connectors. Any help please
