Page 2 of 3
Re: V4 Carb Sync Guide
Posted: Fri Feb 22, 2013 9:58 pm
by bikemonkey
I would think so speedy, check your haynes, should have the differences in there
Posted: Tue Apr 02, 2013 8:46 pm
by Sunnyday
Update on balancing my carbs - NC30.
I found sucking on the vacum pipe and then sliding a screwdriver up the pipe is all it needed and ran as normal while i went to work, it has took me a few goes but i have managed to get them balanced nicely ....all i will say is you will need have small hands to get away with a 7 mm socket i souced a flexi screwdriver that took the 7 mm socket which made it easer but still hard work to get it on and off the adjusters, i sugguest you have two people , one to start the bike each time you make an adjustment to save getting off your back every time start the bike to look at the guages.
Posted: Fri Jul 19, 2013 12:04 am
by shaneo
bikemonkey, is that a morgan carbtune you used?
http://www.carbtune.co.uk/carbdtls.html
if so, how do you find it to use? ok bit of kit?
Posted: Fri Jul 19, 2013 7:53 am
by bikemonkey
Yeah it was.
Was pretty easy to use, nice bit of kit
Posted: Thu Jul 25, 2013 8:08 pm
by Sunnyday
2nd that - that's what i used silly simple you can not go wrong.
Posted: Wed Jul 31, 2013 4:29 am
by shaneo
excellent! just ordered one and now the wait for it to arrive on the other side of the world :/
Posted: Sun Aug 18, 2013 12:34 pm
by NC35Race
Posted: Fri Aug 29, 2014 2:32 pm
by eeikcud
Just a nooby question. Do we leave the carb rubber off or we fit them also while doing the sync?
Posted: Sun Aug 31, 2014 9:45 am
by bikemonkey
The inlet rubbers?
Leave them on dude.
Posted: Sun Mar 13, 2016 10:44 am
by crookzy1
Thanks for this guide.
If you either don't have a carb balancer, or you don't have the tools/skill to adjust the screws whilst the carbs are on the bike, you can do the following.
Take the carbs off the bike and observe the butterfly valve for carb 4. Adjust the idle screw for carb 4 until the butterfly valve reveals the first of the very small holes inside the carb. Adjust the idle screw it until all you can see of this first hole is a minuscule crescent. Adjust the screws for the other three carbs so that they match this crescent as precisely as possible.
This was recommended to me by Rick Oliver and it seems to have worked a treat. Of course you'll only be able to tell for sure by checking with a balancer but they sound right to me.
